Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So, I found (in this forum from 2015 ) a nice working lisp that edits block attributes in sequence with prefix and suffix, etc. See attached "attribute_sequential_increment_NEW.lsp". However, the lisp updates the first attribute tag it finds, so is it possible to incorporate the "get attribute function.lsp" code into it to make it work on custom blocks. See attached "Get attribute list code". I thought it would be as easy as copying the attribute code into the sequence lisp, but it did't do anything on my end. So I don't know if Im doing something wrong here or what needs to be updated.
Thanks in advance.
