MergeTextStyles don't working HELP!!!!
ndnam7693
ndnam7693
Hi every body,
I've problem with attach lisp below. I load the lisp successfull but when I command that lisp don't work (don't working pop up). Please Help me, Can you resolve this lisp ? :(( . Thanks and Best Regards
ВeekeeCZ
You're missing the MyDialogs.dcl file.
ndnam7693
Can you guide me load this lisp? I have this file but I don't know how to use. 😞
pbejse
You need to place "MyDialogs.dcl" where Autocad can find it:
Option 1 : Place the file in C:\program files\autodesk\autocad 20###\support < Your Autocad Version
Option 2:  Place the file in "C:\Users\YourUserName\Documents" then add the folder at Options/Files/Support File Searcg Path.  (or any other folders where you saved the "MyDialogs.dcl" )
Option 3: Replace all instances of (load_dialog "MyDialogs.dcl") to (load_dialog "c:\WhereMyDCLfilesIsSave\MyDialogs.dcl") inside "MergeTextStyles.lsp"
HTH
ndnam7693
Thanks for your help.
