custom menu command: how to write a file's path to switch an xref?
boicottms
boicottms
I wuant to do some menu commands to quickly switch the referenced file (I have a plan under a section and I want to change floors). Copying the commands from the F2 window (and the relative path from the xref window) they should be
^C^C-xref;p;plan;.\MRNC-AE-P00_groundFloor.dwg
^C^C-xref;p;plan;.\MRNC-AE-P01_firstFloor.dwg
…and so on.
But the path is not recognized: it stops at the dot and waits for the rest of the path.
I tested also enclosing the path in 'quotes (single and double), and also tryied to escape special characters, but the command doesn't recognize it as a path.
It wors as expected on the command line.
What's the correct syntax?
Thank you
Thank you
ВeekeeCZ
Try / instead of \
Also if you have path with spaces, you would need to wrap it into ""
boicottms
Hi, can you specify?
I tested
^C^C-xref;p;plan;".\MRNC-AE-P01_firstFloor.dwg";
^C^C-xref;p;plan;"\.\\MRNC-AE-P01_firstFloor.dwg";
^C^C-xref;p;plan;"/.\MRNC-AE-P01_firstFloor.dwg";
^C^C-xref;p;plan;"\.\/MRNC-AE-P01_firstFloor.dwg";
trying to use backslash to escape the special characters without success.
Thank you
ronjonp
Maybe try: (findfile ".\MRNC-AE-P00_groundFloor.dwg")
I dont use xrefs much but a manual check of steps.
: -XREF
External References [? to list external references/Attach/Overlay/Bind/Detach/Path/Reload/Unload] <Attach>:p
Externally referenced drawing(s) to edit path <*>
Plan ?? screws up
ВeekeeCZ
If the MRNC-AE-P00_groundFloor.dwg is stored one level above, then...
^C^C-xref;p;plan;../MRNC-AE-P00_groundFloor.dwg
Or possibly if there is a space in
^C^C-xref;p;plan;"../MRNC-AE-P00_groundFloor 1.dwg"
boicottms
"Plan" is the xref name the command is asking for
