Menuload Lisp Rotine Help
ASCunningham
Message 1 of 10
ASCunningham
I'm not very good at Lisp so I cannot figure out why this routine prompts me for a customization file. I think I have that already set but after starting AutoCAD you are prompted to enter a file name. Any help is much appreciated. Thanks
(defun find-menu-file (menu / mnuFile)
  (if (or (setq mnuFile (findfile (strcat menu ".cuix")))
      ); or
    mnuFile
(if (setq mnuFile (find-menu-file "f:\\autocad\\ba-menu\\barton"))
      (command "menuload" mnuFile)
Replies (9)
Message 2 of 10
it probably cant find the given menu file
Message 3 of 10
ASCunningham
I'm prompted to enter a custom menu name. Shouldn't this already be set from the lisp routine
Message 4 of 10
ASCunningham
No it finds the menu and its loaded.
But its like the lisp routine is running again (repeating) itself. I don't think I have all the parentheses correct?
Message 5 of 10
john.uhden
      ); or   OR WHAT?
    mnuFile
Although if it is found, then the or is superfluous.
But I am still running only ACAD2002, where MENULOAD is looking for a .MNU file.
Is that the right command to load a .CUIX file also?
John F. Uhden
Message 6 of 10
ActivistInvestor
MENULOAD requires the path to a .cuix file.
      ); or   OR WHAT?
    mnuFile
Message 7 of 10
ActivistInvestor
If the .cuix file is already loaded, MENULOAD repeats the prompt.
Try this:
(defun menuload (filename / path)
   (if (setq path (findfile (setq path (strcat filename ".cuix"))))
      (progn
         (command "._MENULOAD" path)
         (if (eq (getvar "CMDNAMES") "MENULOAD")
            (command)
      (princ (strcat "\nError: Customization file " filename " not found."))
Message 8 of 10
ASCunningham
Although the code doesn't have any error's when I run the routine, it doesn't load the menu if it's unloaded.
Message 9 of 10
ASCunningham
After doing some reading this is what I found
The reason is that once a Menu is loaded into AutoCAD, AutoCAD remembers it and reloads it from then automatically. You need to check to see if it is loaded before attempting to load it again or the routine will crash. Use the (menugroup) function to check.
In bold below is what I had to add to keep the routine from crashing. I'm sure there is a cleaner way if anyone would like to chime in. Thanks for all the help
           ); or
    mnuFile
(if (not (menugroup "BA"))
Message 10 of 10
ActivistInvestor
Not true.
If you look at the code, you'll see that you can't include an extension.
If you call the function with only the name of the menu file, it loads the menu:
Command: (command "._MENUUNLOAD" "APPMANAGER") ._MENUUNLOAD Enter the name of a Customization Group to unload:APPMANAGER Customization file unloaded successfully. Customization Group: APPMANAGER Command: (menugroup "APPMANAGER") nil Command: (menuload "appmanager") ._MENULOAD Customization file loaded successfully. Customization Group: APPMANAGER
