measure the Polyline from the rectangle
jessicatyler0007
Message 1 of 23
jessicatyler0007
Hi Everyone,
I'm trying to measure the alignment from the rectangle, The need to ask the import width and height which the rectangle alignment is to be measured. Also need alignment labeling which should be indicate the length of the polyline at the beginning and end of the polyline.
See attached drawing for better understanding.
Replies (22)
Message 21 of 23
jessicatyler0007
@marko_ribar ,
I have always been praising dlanorh, They provide a fantastic code with extras suggestion, although I believe that talent does not depend on anybody's likes and dislikes, if one does not compliment the work It means that he did bad work, it is not so such..
Message 22 of 23
dlanorh
@jessicatyler0007 wrote:
I think the box should not change its place even if the width of the box increases, because if we keep the width of the box more than the distance of the measurement, it will automatically overlap between the sheets. Please remove this option "Enter Minimum Sheet Overlap Distance" instead let the option to measure distance of polyline. And if one thing is possible add this where the box goes out of alignment, Then change the box to two or more pieces, but it should not have an effect on the next box. As this alignment is divided into 24 sheets from the distance.
That is what I am trying to accomplish. The minimum sheet overlap distance is there so you can make minor adjustments which may solve minor problems.
This is a linear program, you can only change the position of the current rectangle not the previous one and that is the problem.
I have further refined the proceedure, and the attached covers all of the polyline.
I am not one of the robots you're looking for
Message 23 of 23
jessicatyler0007
Good Morning @dlanorh ,
Thanks for updating lisp, it's great., The changes shown below are required.
1) The chainage at the beginning and end of the polyline can be given in the mledger?
2) The label of the line is required in the middle of every box.
3) The minimum overlap distance between the box should be set to zero and above.
4) The above serial no. 1) and 2) should be in the choice of yes or no.
