hello everyone,
I have a lisp been using it for a while, it's matchtext, that will match height, layer and text as well with windowselection.
can this be modified to match to have the same ability but for mtext ?
please let me know.
attached is the lisp, feel free to use it as well.
regards,
waseem
Solved by Kent1Cooper. Go to Solution.
Try this simple addition:
(if (setq ss (ssget "_:L" '((0 . "*TEXT"))))
In theory change the "TEXT" in the ssget filter to "*TEXT". Problems arise if you're going from mtext to text and the mtext has inline formatting and vice versa where you will lose any formatting.
I am not one of the robots you're looking for
@Kent1Coopercould you please send it in full lisp, because I don't know where to add this. thanks
@dlanorhwhat I need is same as this lisp to work for mtext, so I thought that to share this and get it modified or if you could make a new one that can work for mtext with changing layer colour, name, height and mtext contents.
regards,
