Visual LISP, AutoLISP and General Customization
match block scale
8 REPLIES 8
Message 1 of 9
3163 Views, 8 Replies
match block scale
Anyone knows something to match scale from one block to another?
match block scale
8 REPLIES 8
Message 2 of 9
extract group codes 41, 42 & 43 then subst it to the target block.... simple and easy
41 x scale factor
42 y scale factor
43 z scale factor
41 x scale factor
42 y scale factor
43 z scale factor
Message 3 of 9
(defun c:mbl ()
(setq fb (entget (car (entsel "\nSelect Block reference: ")))
fb41 (assoc 41 fb)
fb42 (assoc 42 fb)
(setq sb (entget (car (entsel "\nSelect target Block: ")))
sb41 (assoc 41 sb)
sb42 (assoc 42 sb)
(setq sb_ent (subst fb41 sb41 sb))
(entmod sb_ent)
(setq sb sb_ent)
(setq sb_ent (subst fb42 sb42 sb))
(entmod sb_ent)
(command "regen")
try this one, feel free to modify it to suit your needs
glad to help a newbie.... i'm one as well , not really... c",)
(defun c:mbl ()
fb41 (assoc 41 fb)
fb42 (assoc 42 fb)
sb41 (assoc 41 sb)
sb42 (assoc 42 sb)
(entmod sb_ent)
(setq sb sb_ent)
(entmod sb_ent)
(command "regen")
Message 4 of 9
That's IT. Thanks very much!
Message 5 of 9
Can be improved to work with dynamic blocks and attributes?
Message 6 of 9
gennaro
gennaro
Impressive! This has been very handy. Could you please add a prompt such as "enter MBL" to run lisp. Thanks!
Message 7 of 9
Kent1Cooper
in reply to: gennaro
Kent1Cooper
@gennaro wrote:
.... Could you please add a prompt such as "enter MBL" to run lisp. Thanks!
Just add a line at the end:
(prompt "\nEnter MBL to Match BLock scales.")
Kent Cooper, AIA
Kent Cooper, AIA
Message 8 of 9
gennaro
in reply to: Kent1Cooper
gennaro
Awesome! That works! Much appreciated.
Message 9 of 9
paliwal222
paliwal222
sir,
its,
perfect, and work very well.
sir,
its,
AutoCAD Inside the Factory
