Mass move block to nearest polyline
eoconnor95662
Message 1 of 51
eoconnor95662
As noted in title I would like a LISP command to mass move blocks to nearest polyline. I've researched and found commands like lee mac's move block to polyline but it doesn't work in mass. Any feedback or existing AutoCAD functions would be much appreciated.
Accepted solutions (3)
Replies (50)
Message 2 of 51
dlanorh
Define MASS? Is it all blocks in the drawing, blocks you select, blocks on a certain layer, blocks with a specific name?
I am not one of the robots you're looking for
Message 3 of 51
eoconnor95662
Blocks that I can select would be the easiest for me as I only would want to select a couple different blocks that repeat with different attributes. A name(s) for blocks would also work.
Message 4 of 51
pendean
Community Legend
Community Legend
Move the block from where, the nearest point to the Pline, or the block's Insertion point, or something else?
Are you trying to control spacing between the blocks once at the Pline, or it does not matter?
Are you just trying to align blocks in general? Or is the Pline of significance?
Message 5 of 51
eoconnor95662
Move the block from current distance (dist= "1-7" away) to the nearest Pline (not nearest vertex of Pline) from block's Insertion point or nearest block edge.
Block should be touching the Pline
All blocks to be moved are circular, Pline is significant because it is not a Line and can bend away from the block to be moved.
Message 6 of 51
eoconnor95662
Block should be touching the Pline and need to keep relative distance between other blocks (can't stack all blocks on 1 spot on PLINE)
All blocks to be moved are circular - and need to be aligned to PLINE.
I would like a LISP routine that takes specific block(s) from a drag window, targets the nearest Pline (or Pline vertex? as long as its not too far away) and moves it to touch the line.
Thank you for the help!
Message 7 of 51
eoconnor95662
Using the attached code from post - https://www.cadtutor.net/forum/topic/59757-mass-move-blocks-to-nearest-line/ - (looks reasonable for what I want) I get the following description/error in cmd prompt:
Select objects: Specify opposite corner: 0 found, 2 total
Select objects:
; error: bad argument type: lselsetp nil
What am I doing wrong?
Message 8 of 51
dlanorh
One of the selection sets has nothing in it, probably the line selection set as this is restricting the line entities selection to a single layer "A-WALL-INTR"
If this layer is not in your drawing, or there are no ARC's ,CIRCLE's ,ELLIPSE's ,LINE's ,LWPOLYLINE's ,POLYLINE's or SPLINE's on this layer then you will get a nil selection set.
Remove this line near the top of the lisp, or just comment it out with a ; in front of it as shown below.
;(cons 8 "A-WALL-INTR")
Message 9 of 51
eoconnor95662
IN this code, is there a way to determine how far away the block is placed from the line? This code works fine but I would like a way to set distance from the line (so blocks are touching on side not completely centered)
Message 10 of 51
dlanorh
That is possible, but it is better to do it after the block is moved provide the circle radius is obtainable.
Message 11 of 51
eoconnor95662
RADIUS 5.000
Message 12 of 51
dlanorh
Try this. I've not tested it as I don't have the blocks
(defun c:m2l ( / l_ss b_ss b_cnt b_ent i_pt min_dist m_pt l_cnt l_ent c_pt md m_ang)
  (prompt "\nSelect Lines : ")
  (setq l_ss (ssget "_X" '((0 . "ARC,CIRCLE,ELLIPSE,LINE,LWPOLYLINE,POLYLINE,SPLINE"))))
  (prompt "\nSelect Blocks : ")
  (setq b_ss (ssget '((0 . "INSERT"))))
  (repeat (setq b_cnt (sslength b_ss))
    (setq b_ent (ssname b_ss (setq b_cnt (1- b_cnt)))
          i_pt (cdr (assoc 10 (entget b_ent)))
          min_dist 1000000
          m_pt nil
    (repeat (setq l_cnt (sslength l_ss))
      (setq l_ent (ssname l_ss (setq l_cnt (1- l_cnt)))
            c_pt (vlax-curve-getclosestpointto l_ent i_pt)
      (cond ( (< (setq md (distance i_pt c_pt)) min_dist)
              (setq min_dist md
                    m_pt c_pt
    (setq m_ang (angle i_pt m_pt)
          m_pt (polar i_pt m_ang (- min_dist 5.0));;5.0 = radius of circle in block
    (vla-move (vlax-ename->vla-object b_ent) (vlax-3d-point i_pt) (vlax-3d-point m_pt))
  (princ)
Message 13 of 51
eoconnor95662
Thanks for the useful code. I was wondering if you could make 2 small modifications to it.
One is to have it move to a specific line layer (SPPC-E-EL) , the other is to have it only select certain block type names (552-2, 551-1, and 552-0-CO).
Thanks again,
Message 14 of 51
dlanorh
  (setq b_ss (ssget '((0 . "INSERT") (2 . "552-2,551-1,552-0-CO"))))
          min_dist 1000000
          m_pt nil
              (setq min_dist md
                    m_pt c_pt
  (princ)
The above will only allow the selection of  blocks named 552-2, 551-1, and 552-0-CO
Sorry but I'm a bit brain dead at the moment. Move what to the specific line layer "SPPC-E-EL", the lines or the blocks?
Message 15 of 51
eoconnor95662
Move the aforementioned blocks to the line, which happens to be on layer SPPC-E-EL. The blocks are not on this layer. This is done mainly done to avoid it jumping to nearby lines that are not the desired line.
This seems to do the trick, let me know if I errored.
Message 16 of 51
dlanorh
OK. I think this does what you want. It only selects lines on layer "SPPC-E-EL", and only the named blocks.
  (setq l_ss (ssget "_X" '((0 . "ARC,CIRCLE,ELLIPSE,LINE,LWPOLYLINE,POLYLINE,SPLINE") (8 . "SPPC-E-EL"))))
          min_dist 1000000
          m_pt nil
              (setq min_dist md
                    m_pt c_pt
  (princ)
Message 17 of 51
jtm2020hyo
awesome code, thanks for your contribution.
Message 18 of 51
mbaxterB9TKM
This is my first post, so sorry if this is in the wrong place but it seemed like this thread was the closest thing I could find to what I am looking for. I slightly adjusted the lisp routine mentioned above to work for selected polylines instead of blocks. I thought it did exactly what I wanted until I realized that the perpendicular distance between my polylines was not maintained. Is there a way to maintain the perpendicular distance between the polylines? We set up our drawings with DVIEW's instead of UCS views because we like to leave the drawing in world view. I only make that distinction because I think it makes everything a little more complicated for the lisp.
I have attached an image of what I am looking to do. We have a crosswalk who's stripes need to be 2' apart from each other. The stripes are always parallel to the curb. I have a line from the center of one ADA ramp to another. I would like all the stripes to be along this line as shown in the image on the right. Again I need the perpendicular 2' spacing maintained. Please let me know if this is possible with a lisp. I am a total newbie with lisps so please speak in layman's terms 🙂
Thank you!
Message 19 of 51
dlanorh
Try this.
(defun c:m2l2 ( / ent s1 e1 ss cnt lent el mpt ipt)
  (setq ent (car (entsel "\nSelect Centreline : "))
        s1 (cdr (assoc 10 (entget ent)))
        e1 (cdr (assoc 11 (entget ent)))
  );end_setq
  (prompt "\nSelect Lines to Move : ")
  (setq ss (ssget ":L" '((0 . "LINE"))))
  (cond (ss
          (repeat (setq cnt (sslength ss))
            (setq el (entget (setq lent (ssname ss (setq cnt (1- cnt)))))
                  mpt (mapcar '(lambda (x y) (/ (+ x y) 2.0)) (setq s2 (cdr (assoc 10 el))) (setq e2 (cdr (assoc 11 el))))
                  ipt (inters s1 e1 s2 e2 nil)
            );end_setq
            (cond (ipt (vlax-invoke (vlax-ename->vla-object lent) 'move mpt ipt)))
          );end_repeat
  );end_cond
  (princ)
);end_defun
 Once loaded type M2L2 to run.
Message 20 of 51
mbaxterB9TKM
I tried the lisp above and got the following error:
; error: bad argument type: 2D/3D point: nil
