MAPCAR optimization
MAPCAR optimization
Browning_Zed
Message 1 of 23
MAPCAR optimization
Browning_Zed
Hi All,
I have a need to check if the variables v1 v2 v3 "" are equivalent, and if true, then set these variables to nil. To solve this problem, I created the following code:
(mapcar
	'set '(v1 v2 v3)
	(mapcar
		'(lambda ( x ) (if (= "" x) (setq x nil) x))
		(list v1 va2 v3)
My question is, is it possible to optimize this code so as not to repeat the list of variables twice? That is, exclude the repetition
'(v1 v2 v3) and (list v1 v2 v3) and define the list of variables once.
Accepted solutions (3)
Replies (22)
Message 21 of 23
ronjonp
Could even be as simple as this .. assuming that all symbols need to = "" before they get set to nothing.
(if (= "" v1 v2 v3)
  (mapcar 'set '(v1 v2 v3) '(nil nil nil))
Message 22 of 23
john.uhden
@ronjonp
Once again, since we may not know how many variables are in the list, then...
;; Say (setq lst '(v1 v2 v3 vn))
(and
  (listp lst)
  (vl-every '(lambda (x)(= (eval x) "")) lst)
  (not (foreach item lst (set item nil)))
;; Hmm, I think this would work...
(mapcar 'set lst '(nil nil nil nil nil nil nil nil nil etc))
John F. Uhden
Message 23 of 23
ronjonp
@john.uhden wrote:
@ronjonp
(and
  (listp lst)
For sure ... I'd group these as a list like so then just nullify the list as a whole:
(setq l '("" "" ""))
(if (apply '= (cons "" l))
  (setq l nil)
I'd like more context as to where the OP is going with this though. Correct structure in code makes a world of difference with these trivial tasks.
