MAPCAR optimization
MAPCAR optimization
Browning_Zed
Message 1 of 23
MAPCAR optimization
Browning_Zed
Hi All,
I have a need to check if the variables v1 v2 v3 "" are equivalent, and if true, then set these variables to nil. To solve this problem, I created the following code:
(mapcar
	'set '(v1 v2 v3)
	(mapcar
		'(lambda ( x ) (if (= "" x) (setq x nil) x))
		(list v1 va2 v3)
My question is, is it possible to optimize this code so as not to repeat the list of variables twice? That is, exclude the repetition
'(v1 v2 v3) and (list v1 v2 v3) and define the list of variables once.
Accepted solutions (3)
Replies (22)
Message 2 of 23
hak_vz
No you can not. First list '(v1 v2 v2) is list of variable names, and other is list of values). Check autolisp function QUOTE (short ') and what it does.  Check here quote explanation from @Lee_Mac
Miljenko Hatlak
Message 3 of 23
pbejse
@Browning_Zed wrote:
Hi All,
As per your code
(Setq v1 "Cake" Va2 "" v3 "")
(mapcar '(lambda ( x )
	   (set x (if (/= "" (eval x))(eval x) nil  )))
		'(v1 va2 v3)
Result is
("Cake" nil nil)
_$ v1
"Cake"
_$ va2
nil
_$ v3
nil
If you are not planning to use the resulting list from mapcar function, this will be enough
(foreach itm '(v1 va2 v3)
  (if (eq "" (eval itm))
    (set itm nil)
Or are you saying if any of the variables is ""  then set all to nil?
Message 4 of 23
Browning_Zed
You understood me correctly, I needed to check each variable separately.
But I'm also interested in the option if any of the variables is equivalent to "" then return nil. How can this be done?
Message 5 of 23
hak_vz
(if (= (apply '+ (mapcar 'strlen (list v1 v2 v3))) 0) (mapcar 'set '(v1 v2 v3) '(nil nil nil)))
Miljenko Hatlak
Message 6 of 23
Browning_Zed
Thanks. But in this case, you have to repeat the list again. Is it possible to do the same without repeating the list of variables? Perhaps the FOREACH function?
Message 7 of 23
hak_vz
You need to check equivalency of v1 v2 v3, this is first list appearance. In second part if condition is true we assign values to all variables to nil. It's then completely irrelevant how you do it, either with foreach or mapcar. Those two functions are practically  similar.
You can read this
as
(if (= (apply '+ (mapcar 'strlen (list "" "" ""))) 0) (mapcar 'set '(v1 v2 v3) '(nil nil nil)))
Or with foreach
(if (= (apply '+ (mapcar 'strlen (list v1 v2 v3))) 0) (foreach e '(v1 v2 v3) (set e nil)))
Miljenko Hatlak
Message 8 of 23
pbejse
There's a couple of ways to do that. [ you only "see" the list of variables once ]
((lambda (l)
   (if (vl-some '(lambda (x) (= (eval x) "" )) l)
     (foreach itm l (set itm nil)))
  '(v1 va2 v3)
If you want to see a result, you can add (mapcar 'eval l) as else in the if condition.
Either way, you need to define the list of variable names
  • as an argument for mapcar/vl-some/vl-every/foreach....
  • as the invidual names to be assigned a value
Message 9 of 23
Browning_Zed
Thanks pbejse. This option is the most suitable for me. But what do you think about the VL-EVERY function? Is it possible to do optimization using this function? Like this:
(vl-every '/= '("" "") (list v1 v2))
but is there a way to get rid of the '("" "")
Message 10 of 23
pbejse
I believe the condition were if "any" of the variable. I could be wrong but what you had applies to  if ALL variable is equivalent to "" then set to nil.
Message 11 of 23
pbejse
That is the reason why i ask earlier for the condition, Vl-every means "ALL" while vl-some "if any"
To answer you're question It actually depend on the variable type you are testing,
If you dont want to define a predicate function (lambda) you can do it this way
(Setq v1 "d" V2 "" v3 ""
(vl-every 'snvalid (list v1 v2 v3)) --> nil because v2 and v3 is invalid value
(Setq v1 "d" V2 "e" v3 "f")
(vl-every 'snvalid (list v1 v2 v3)) --> T because all three are valid
HTH
Message 12 of 23
hak_vz
@pbejse
@Browning_ZedStated "I have a need to check if the variables v1 v2 v3 "" are equivalent"
But if any of condition "any" apply then your solution works.
Or in my version without using vl functions
(if (member 0 (mapcar 'strlen (list v1 v2 v3))) (mapcar 'set '(v1 v2 v3) '(nil nil nil)))
There are so many options to write it.
Miljenko Hatlak
Message 13 of 23
Browning_Zed
, thank's man. This is what I need, you are cool.👍
Message 14 of 23
pbejse
All is well now, It all became so clear at post # 9
Cheers
Message 15 of 23
Browning_Zed
OOPS. As it turned out, SNVALID checks other characters and if the value is also equivalent to "=" or "*", or "|" this returns nil as well. It doesn't suit me.
Message 16 of 23
pbejse
...also equivalent to "=" or "*", or "|"  ... it doesn't suit me.
There you go. now you got it. It all depends on the condition/function.
Then you need to define a function
(vl-every '(lambda (x)
		    (/= "" x )) (list v1 v2 v3))
Message 17 of 23
Browning_Zed
YEAH! This is it!
Message 18 of 23
john.uhden
Another way to approach this is to see what's left after removing empty strings...
(defun remove_blank (lst)
  (vl-remove-if '(lambda (x)(= x "")) lst)
John F. Uhden
Message 19 of 23
ronjonp
Another maybe:
(mapcar 'set '(v1 v2 v3) '("" "" ""))
(if (apply '= (list "" v1 v2 v3))
Message 20 of 23
john.uhden
Very good!
Ya know most, if not all, the mapcar examples dealt with symbol names, but
mine did not. Nor did mine set any symbols to nil. Maybe I should think
before I write.
Anyway, since there's no knowing how many symbols might be in the list,
foreach might be the simplest approach...
(foreach item lst
(if (= (eval item) "")(set item nil))
Of course that still leaves the list as '(v1 v2 v3 vn) if that matters.
John F. Uhden
