making layer filter
making layer filter
diegolopezsilanes
making layer filter
diegolopezsilanes
Hi, I´m trying to modify a lisp for making layer filters and Im having the following problem :
; error: grupo DXF erróneo: (-3 ("ACAD" (1000 . FN2)))
in english:
; error: wrong DXF group: (-3 ("ACAD" (1000 . FN2)))
thanks
(defun c:ADDLayerFilter ( / dc fn xd )
	(setq fn (getstring "\nFilter name: "));set filter name and filter string
	(setq fn2 (strcat "(NAME==\*" fn "*\")" ))
	(setq fn2 (vl-string-subst "" " " fn2))
    (if
        (and
            (setq xd
                (cdr
                    (assoc 360
                        (entget
                            (cdr
                                (assoc 330
                                    (entget
                                        (tblobjname "layer" "0")
            (or (setq dc (cdr (assoc -1 (dictsearch xd "ACAD_LAYERFILTERS"))))
                (setq dc
                    (dictadd xd "ACAD_LAYERFILTERS"
                        (entmakex
                                (000 . "DICTIONARY")
                                (100 . "AcDbDictionary")
                                (280 . 0)
                                (281 . 1)
            (null (dictsearch dc fn))
        (dictadd dc fn
            (entmakex
                (list
                   '(000 . "XRECORD")
                   '(100 . "AcDbXrecord")
                   '(280 . 1)
                    (cons 1 fn)
                   '(001 . "~*|*")
                   '(001 . "*")
                   '(001 . "*")
                   '(070 . 0)
                   '(001 . "*")
                   '(001 . "*")
                   '(-3
                            "ACAD"
							(1000 . fn2)
    (princ)
ВeekeeCZ
in english:
thanks
    (if
        (and
            (setq xd
                (cdr
                    (assoc 360
                        (entget
                            (cdr
                                (assoc 330
                                    (entget
                (setq dc
                        (entmakex
                                (280 . 0)
                                (281 . 1)
        (dictadd dc fn
            (entmakex
                (list
                   '(000 . "XRECORD")
                   '(280 . 1)
                    (cons 1 fn)
                   '(001 . "~*|*")
                   '(001 . "*")
                   '(001 . "*")
                   '(070 . 0)
                   '(001 . "*")
                   '(001 . "*")
                   (list -3
                        (list
			  "ACAD"
			  (cons 1000 fn2)
    (princ)
Once you use a variable or a function the list has to be valuated.
'((0 . "MyFilter")) is ok.
'((0 . flt)) fails
(list (cons 0 flt)) is ok.
Anyway, whats wrong about using (command "_.-layer" "filter" ...) It's definitely simpler and the speed is not a question since you are not creating filters every minute.
diegolopezsilanes
thanks beekeecz ur wonderful
