Making a list of amounts of each numbers
koseku3
koseku3
Hello people,
For instance i have texts in drawing as: 1 2 2 3 3 3
So i want a lisp which can give me a list like this:
1(1)
2(2)
3(3)
So i can know how many are there from each value at drawing?
note: these numbers are in seperate texts
I hope i could tell my request, sorry for bad english....
DannyNL
There's probably a better way but here is my quick code.
It just counts text, so it's not limited to only numbers. So if you have A A B C, you can count them as well.
(defun c:TxtCnt (/ TC_Selection TC_Count TC_Text TC_Found TC_CountList)
   (setq TC_Selection (ssget '((0 . "TEXT"))))
   (if
      TC_Selection
        (progn
           (setq TC_Count 0)
           (repeat (sslength TC_Selection)
              (setq TC_Text (vla-get-TextString (vlax-ename->vla-object (ssname TC_Selection TC_Count))))
              (if
                 (setq TC_Found (assoc TC_Text TC_CountList))
                   (setq TC_CountList (subst (list TC_Text (1+ (nth 1 TC_Found))) TC_Found TC_CountList))
                   (setq TC_CountList (append TC_CountList (list (list TC_Text 1))))
              (setq TC_Count (1+ TC_Count))
   (if
      TC_CountList
        (progn
           (textscr)
           (foreach TC_Item (vl-sort TC_CountList '(lambda (TC_A TC_B) (< (car TC_A) (car TC_B))))
              (princ (strcat "\n" (car TC_Item) " \(" (itoa (cadr TC_Item)) "\)"))
   (princ)
koseku3
Thank you so much for quick reply, this is exactly what i needed! Works perfect.
DannyNL
Nice! Glad I could help Smiley Happy
Kent1Cooper
1(1)
2(2)
3(3)
Maybe not "better," but shorter, anyway:
(defun C:IQR ; = Integer Quantity Report
  (/ ss qua inlist)
  (setq
    ss (ssget '((0 . "TEXT") (1 . "#,##,###")))
    qua (sslength ss)
    intlist ; list of text contents converted to integers
      (mapcar 'atoi
        (mapcar '(lambda (x) (cdr (assoc 1 (entget (cadr x)))))
          (vl-remove-if '(lambda (y) (listp (cadr y))) (ssnamex ss))
        ); mapcar
      ); mapcar
  ); setq
  (foreach int (vl-sort intlist '<); ascending numerical order, once each
    (prompt (strcat "\n" (itoa int) " (" (itoa (- qua (length (vl-remove int intlist)))) ")"))
  ); foreach
  (princ)
); defun
That also restricts it to only integer-content Text of up to three digits.  If yours would be all only one  digit as in your example, change the "#,##,###" in the filter list to just "#"; for two digits, "#,##"; if they might sometimes go to four digits, use "#,##,###,####"; etc.
It converts the text content to integers  [which means it has to convert back for the prompts] because it can then more easily report them in order of numerical value.  If you have a list of text-string contents like this:
("3" "1" "2" "123")
sorting by text-string value results in this:
("1" "123" "2" "3")
whereas converting them to integers and sorting gives this:
(1 2 3 123)
EDIT:  As with @DannyNL's routine, it requires the User to select objects  [though in each routine you can grab a whole area with a window, lasso, etc., and it will "see" only the appropriate objects].  But if you want it to report all such objects in the entire drawing, without the User needing to select  them, change this line:
to this:
    ss (ssget "_X" '((0 . "TEXT") (1 . "#,##,###")))
Kent Cooper, AIA
