macro
macro
tader1
macro
tader1
Hi, can get a little help with a macro.
(command "insert" "tick.dwg" "S" lts TickerPoint ang "" "")
doesn't work when
lts 30.0
tickerpoint (126.34 10.7243 0.0)
ang -66.3458
Still inserts the dwg, but something's not quite right.
TIA, Shawn
Shawn,
remove last two double quotes.
try this, it works for me.
(command "insert" "tick.dwg" "S" lts TickerPoint ang)
Amit Vedak
Devyani CAD Software Developments
Web Site:- http://www.devcs.com
Email:- amit@devcs.com
If the osmode is set to a value other than 0 it snaps to the snappoint
if it so than you can try
(command "insert" "tick.dwg" "S" lts "_NON" TickerPoint ang)
good luck
Harrie
Hi Shawn,
I think more correctly yet you will turn off
echo and snap before and don't forget 'bout minus sign
in front of 'insert':
[code]
(setvar "cmdecho" 0)
(setvar "osmode" 0)
(command "-insert" "tick.dwg" "S" lts TickerPoint ang)
(setvar "osmode" 703);your old snap here
[/code]
HRU?
~'J'~
tader1
Hi guys, thnx for the input. I've always had problems with macros... I don't know why. I'll try the suggestions.
