Macro to redefine block only
M_c3d
Advisor Advisor
Message 1 of 9
M_c3d
I've written the macro below to redefine a specific block in an open drawing.  It work's OK apart from it does not escape the command at the end, it continues the -insert command and asks to specify point etc
^C^C-insert logo= c:\new\logo Y^C
Any ideas?
Thanks in advance!
Replies (8)
Message 2 of 9
ronjonp
Try this instead:
^C^C(command "-insert" "logo=c:\\new\\logo.dwg" nil)
Message 3 of 9
Moshe-A
@M_c3d  hi,
try this
^C^C-insert "logo=c:\new\logo Y" ^C
pay high attention to spaces as you know it's interpret as enters.
Moshe
Message 4 of 9
M_c3d
 Hi @Moshe-A
Thanks for your help.  It returned;
Command: -insert Enter block name or [?] <a$c7a864ac9>: "logo=c:*Cancel*</a$c7a864ac9>
Message 5 of 9
M_c3d
Hi @ronjonp
Command: (command "-insert" "logo=c:*Cancel*
Message 6 of 9
Moshe-A
works perfect here
is your wblock name "logo y"?
does it lay in c:\new folder?
if it does not then fix it by specifying and exact names
are you running an AutoCAD LT?
Message 7 of 9
cadffm
@M_c3d
- The block name is LOGO, right?
- and nobody who need to ask for basic help should use a blank as enter in a menu-macro, use the right character (; semicolon)
 Why: Works more often and is much easier to see&count.
Don't use Backslash in a menu-macro, except you want what it stand for: One User-input.
User SLASHs for the path
^C^C^C_.-INSERT;"LOGO=C:/NEW/LOGO";^C
Generally:
[F1] Command -INSERT
[F1]About Special Control Characters in Command Macros
Sebastian
Message 8 of 9
M_c3d
@Moshe-A  The block name was Logo with the Y for the redefine option.
I'm running civil 3d, but the macro will be for LT users.
Message 9 of 9
M_c3d
Yes the block name was Logo.  That's it now working.  I was aware of the spaces representing returns, I had originally got the code from another post I had made on the issue https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/macro-to-redefile-block/m-p/8717292#...
Thanks for your assistance, much appreciated @cadffm @Moshe-A @ronjonp
