macro not working
macro not working
Joris.vd.Meulen
macro not working
Joris.vd.Meulen
Hey Guys,
We recently installed 2016. And I can't get our menu-item to work like it did before.
What we have:
- custom menu item "bib"
- in our cui > menu > bib > there are several custom 'submenu's migrated from an earlier cui.
- these submenu items have several items or commands as you might wanna call 'm.
- so far nothing failing.
What it used to do:
- trigger a library directory which is a popup window with a tiled showcase of several items (dwg blocks).
Now I get the popup, but all is blank.
The macro which each command in these submenu have (all differ obviously)
^C^C^P(cond ((null i004) (menucmd (setq i004 "I=004USER")) (princ)) (T (menucmd i004) (princ))) ^P$I=*
I'm trying to figur out the point where things go wrong. Since I don't know that much from macro etc. It's a puzzle. Perhaps you can help me?
Autodesk's help guide is not that good (lack of examples etc).
so
- is this macro 'up 2 date'? I know it's written in r13 era ... (yup, we go back a looong time).
- T function is that a custom function or an autodesk one?
love python coding
scot-65
Looks like your icon library did not make it over from the previous version.
I don't have enough experience with icon libraries to guide you. Perhaps
recheck the path (folder) to the icon library.
"T" is typically used to pass the last test inside a COND.
In other words, a default action if none of the previous tests passes.
It is good practice to have such a test inside the COND.
[Vertical] Example:
(cond
( (test1 is true) [execute within these parenthesis only, and skip the rest] )
( (test2 is true) [execute...] )
(T [execute...] )
);cond
For a simple IF statement, "T" is redundant to use as a test...
(if T
(do this)
(do that)
);if
"do that" will never execute...
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Joris.vd.Meulen
Hmm, okay, starts to make sense.
Is it correct if I say that the path you refer to is set in the Acad > options > files > support file search path?
(because the location is added there, not anywhere else)
Or do I have to set this path somewhere else?
love python coding
scot-65
I have no experience with icon libraries.
Perhaps look in the CUI?
Scot-65
