generate blocks and change block / layer and the block entities layer name
E.S.7.9
E.S.7.9
hi everybody
i should create too many different blocks with the same objects , i need a lisp which can help me for gain time.
Simply what i want to do is make a block ,i wanna give the same block and layer name at the same time , after that i will copy that block how many time i need and edit each blocks for to change block and layer names
it would be nice if block entities layernames are changing at the same time and the same name with edit block and layer names
if it is not to crazy wish , can anybody tell me the quick way for to do this or share similar lisp , please
thank you so much (sorry for my englis) 🙂
scot-65
How many is "too many"?
Perhaps investigate the following commands:
GROUP
COPYCLIP / PASTEBLOCK (an un-blocked group of objects)
Perhaps also look into Dynamic Blocks with multiple visible states
and a lookup table to switch visibilities.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Baker_ADG
Bump this topic. I would also like a lisp that generates a block with the name of each layer. A line that is 1.5 long, that is bylayer. I want to use in the legend.
Jon Baker | Land Development & Infrastructure Design Manager
Alignment Design Group | Denver | Colorado
Civil 3D 2025 | Windows 11
Sea-Haven
Do you mean something like this
Why a block ? Its easy to get a layer and make a line and label, can then make into a block if you want,  the only question is how do you decide which layers ? If same most time do once and save in a dwg then just insert into current dwg.
