Macro: Modifying an ".X" Filter not Succesfull
Nik4_99
Nik4_99
Hi all.
I am trying to make a basic customization to a ".X" (and .Y and .Z) command:
^C^C_.Z;\0;
I want to take the X coordinate of the next-selected-point and automatically keep the YZ coordinates of the basic point, so "stretch" (or any other command) would take just the "X" coordinate of the selected point.
However - I select the point to stretch, execute the command, select the point-to-acquire-X-coordinate-from, and I get the still active command with the
of (need YZ):
open prompt at the command line.
It does not accept the selecting of the next point (what I think the "\" should do) and continue with executing the macro.
If I enter manually "0" and then "Enter" - the needed coordinate is obtained, but I get the rest of my Macro command afterwards:
Command: 0
Unknown command "0". Press F1 for help.
Any help on why the ";" is not accepted to execute "Enter" after selecting the point-to-acquire-X-coordinate-from, and finishing the command?
If I replace the ";" with " " does not make any difference.
Thanks in advance,
Cheers
N
cadffm
^C^C_.Z;\0;
Please try it by hand,
start Stretch command, select the stretch area and objects, select the basepoint and PRESS [ESC]
cancel..
doesn't make sense, or? also 2x ESC isn't good in this situation. Get rid of your "^C^C" part:
_.Z;\0;
Start again:
type in _.Z<enter><select a point??>type in 0<enter>....
Can not work this way and BTW: You want to keep YZ, and not Z only
.X;\
.YZ;@;
But if used .YZ filter, the next is for .X only, so you need .YZ only
.YZ;@;\
BTW: for my personla use, ORTHO mode is good enough for often,
[F8] or as temporary switch of current ortho state: Pressing [Shift] while point selection
Sebastian
Nik4_99
Hi Sebastian,
thanks for taking a look.
I had problems posting this topic yesterday at the end of the work, I copy-pasted a few times and eventually I gave up. This morning I got no errors posting, but I made one by myself...
I was experimenting with all coordinates, and I posted here "Z" instead of "X" in my posted macro (despite the "X" mentioned in the Subject) - so there was your correct reply
"BTW: You want to keep YZ, and not Z only"
Here (in this iteration that I posted for help), the code should have looked like this:
^C^C_.X;\0;
I used this method to select the point of a line, then look for a donor for (in this case) X coordinate,  and then enter "0" for next prompt (YZ). This method works manually. With this approach - Double Esc is not a problem (I also tried without it before - no difference).
Anyhow - your approach is working, so thank you very much for your time and help.
Just out of curiosity - if you have time - why is my code (.X;\0;) not working in macro, but it works manually?
Cheers,
Nika
p.s. - ORTHO mode is not working as desired in 3D, especially when I need a closer coordinate (X, for example), as the ortho switches to further one (Y). If we add the Z factor - it rarely acts as I want...
cadffm
Hi Nika,
>> ^C^C_.X;\0;
I can not believe that this is working
- not as macro because of ESC (2x) plus _.X is not an legit input
- and not by typing by hand
I don't know what I could misunderstand, I read your words clearly, but that can't be work.
?? What is wrong in my (or your) side?
>>"With this approach - Double Esc is not a problem (I also tried without it before - no difference)."
No difference doesn't meant that there is no problem with.
>>"Anyhow - your approach is working, so thank you very much for your time and help."
Good to hear.
>>"Just out of curiosity - if you have time - why is my code (.X;\0;) not working in macro, but it works manually?"
Now you wrote .X;\0;
before you wrote ^C^C_.X;\0;
That is not the same! Less 2x ESC and the command name is .X instead the unknown _.X
Let us imagine you really test the user keyboard input as macro:
.X;\0
It works by hand and looks good, what is the problem?
In automation AutoCAD doesn't accept 0 as a real 3D-coordinate (what is correct, wether 2D nor 3D), that's the problem.
By hand, autocad autocomplete a 0 to 0,0,0 but not in a macro inside the .X command.
HTH
Sebastian
Nik4_99
Thank you again for your time and help, Sebastian.
Cheers
Nika
cadffm
Glad to help,
so your macro .X;\0; would working if you change it to .X;\0,0,0; or .X;\0,0,0
but .X;@ is the better one if you like to use the X-Position of the lastpoint (for stretch it is the basepoint, you selected before the target point.
Sebastian
