Drawinghead and bom transfer...
Hey
We are getting some drawings from another company that has Drawings head blocks and BOM blocks inside the file.
We need to transfer the data from this blocks to our blocks. I know this can be done by writing a Lisp script to do the job.
Please help:
I need a lisp script that do the following....
1. Find the block name 'STDHOVED225' remember its insertion point and
insert the block 'BWRS_HOVED' at that insertsertion point.
2. Transfer the data from the block name 'STDHOVED225' to the Block name 'BWRS_HOVED' in the bellow showed tags.
Blockname: STDHOVED225 Transfer to Blockname: BWRS_HOVED
Attribut tag Attribut tag
TEGN1 DESCRIPTION
TEGN2 TITEL
TEGN2 SUBJECT
SERIENO SERIAL
3. Delete the block named 'STDHOVED225' from the drawing.
4. Find the block name 'styklistefelt' remember its insertion point and insert the block 'Part list top'
5. Transfert the Data from block name 'styklistefelt' to the block name 'BWRS_HOVED' in the bellow showed tags.
Blockname: styklistefelt Transfer to Blockname: BWRS_HOVED
TOTALWEIGHT TOTAL
TIMES QUANTITY
6. Transfert the Data from block name 'styklistefelt' to the block name 'Part list top' in the bellow showed tags.
Blockname: styklistefelt Transfer to Blockname: Part list
PCS Qty.
DESCRIPTION Description
ITEM Item
AXXXX-X-XXXXA Drg.
MATERIAL Material
CODE Cert
WEIGHT Weight
7. Count the numbers of items in BOM from the blocks named styklistefelt and Ekstrastykliste. The numbers of BOM items is taken from tags ITEM in the blocksnamed 'styklistefelt' and 'Ekstrastykliste'. this is need in the next step.
8. Find the block name 'Ekstrastykliste' remember its insertion point and its tag 'ITEM' number and insert and replace with the block name 'Part list top' and transfer the below Data from the block named 'Ekstrastykliste' to 'Part list top'.
Blockname: Ekstrastykliste Transfer to Blockname: Part list top
PCS Qty.
ITEM Item
AXXXX-X-XXXXA Drg.
MATERIAL Material
CODE Cert
WEIGHT Weight
9. Repeat the process from 8. until the TWO BOMS are indentical.
10. Delete all the 'Ekstrastyklistefelt' and 'Styklistefelt' blocks.
I have attached a exampel dwg. In modelspace i showed where the tags data value has to be transfer from block to block. In paperspace i have showed and exampel of the two Drawingheads and Boms.
I have also attached a description and the below code.
I have start a of lisp script, just need help to be changede to the upper description, thank you very much in advance:
(defun c:DH2DH ( / ACTLYT ATTLST ATTLST1 ATTS ENT HND I LYT OBJ OBJ1 OLD_LST OLD_REC POS RT S1 S2 SC)
(vl-load-com)
(setq atts '(("TEGN1" "DESCRIPTION") ("TEGN2" "TITEL") ("TEGN3" "SUBJECT") ("SKA1" "SCALE"))
old_rec (getvar 'ATTREQ)
atclyt (getvar 'CTAB))
(setvar 'ATTREQ 0)
(if (setq s1 (ssget "_X" '((0 . "INSERT") (2 . "STDHOVED224") (66 . 1))))
(repeat (setq i (sslength s1))
(setq hnd (ssname s1 (setq i (1- i)))
ent (entget hnd)
lyt (cdr (assoc 410 ent))
sc (cdr (assoc 41 ent))
rt (* (/ (cdr (assoc 50 ent)) pi) 180.0)
attlst nil
attlst1 nil
obj (vlax-ename->vla-object hnd)
attlst (vlax-invoke obj 'GetAttributes)
)setq
(foreach att attlst
(setq old_lst (cons (list (vla-get-TagString att) (vla-get-TextString att)) old_lst))
)foreach
(setvar 'CTAB lyt)
(vl-cmdf "_.-insert" "BWRS_HOVED" "_NONE" (vlax-get obj 'InsertionPoint) sc sc rt)
(if (setq s2 (ssget "_L" '((0 . "INSERT") (2 . "BWRS_HOVED") (66 . 1))))
(progn
(setq obj1 (vlax-ename->vla-object (ssname s2 0))
attlst1 (vlax-invoke obj1 'GetAttributes)
);; setq
(foreach att attlst1
(if (setq pos (vl-position (vla-get-TagString att) (mapcar 'cadr atts)))
(vla-put-TextString
att
(nth (vl-position
(nth pos (mapcar 'car atts))
(mapcar 'car old_lst)
(mapcar 'cadr old_lst)
) if
) foreach
)progn
) if
(vla-delete obj)
) repeat
) if
(setvar 'CTAB atclyt)
(setvar 'ATTREQ old_rec)
(princ)
);; demo
