I'm quite new to macros and LISP so I could use some help.
I made some simple macros to quickly change cannoscale and to reset default scale list (I gave these a keyboard shortcut too).
Here's what I have now (hope someone finds them useful):
^C^C-scalelistedit;R;Y;^C^C→ Reset default scale list
^C^Ccannoscale;1:\^C^C_regenall;→ Change cannoscale and regen. Type in eg. "50" and hit enter ("1:" is there already typed). (works only for existing scales)
^C^Ccannoscale;"1:10";_regenall;→ Change cannoscale to 1:10 and regen.
I added the "regenall" so linetypes are automatically scaled (I have MSLTSCALE, PSLTSCALE and LTSCALE all set to "1")
I would like to have one more macro to add new scales quickly.
Here I need some help:
^C^C-scalelistedit;A;1:\→ Here I type eg. "50" and hit enter ("1:" is there already typed in automaticly)
Next step is to enter scale ratio WHICH IS THE SAME as the name I just typed in. So is there some way to add the "name" here automatically and finish the macro with ;^C^C
Is it possible to make with macro or do I have to use LISP?
(tips where I should start with learning LISP? I'm new to all kinds of coding)
Solved by M.Lindell. Go to Solution.
Solved by ВeekeeCZ. Go to Solution.
Don't think it could be made by a macro. But it's quite simple by LISP.
(defun c:ScaleListAdd (/ s) (if (and (setq s (getint "\nNew scale 1:")) (setq s (strcat "1:" (itoa s)))) (command "_.-scalelistedit" "_add" s s "_exit")) (princ) )
HERE is how to load it. Then a macro would be just the name ^c^cScaleListAdd
Or use this if you want to put it directly to tool palette macro.
((lambda (/ s) (if (and (setq s (getint "New scale 1:")) (setq s (strcat "1:" (itoa s)))) (command "_.-scalelistedit" "_add" s s "_exit")) (princ)))
Tip for your starting point: HERE
Thank you very much @ВeekeeCZ !
I modified it a little. Added "^P" to make it neat and these two: (command "_.cannoscale" s) (command "_regenall").
It sets the new scale current and regens.
Now it's perfect for me 😁 Thanks for your help!
I put it directly in tool palette macro.
^P((lambda (/ s) (if (and (setq s (getint "New scale 1:")) (setq s (strcat "1:" (itoa s)))) (command "_.-scalelistedit" "_add" s s "_exit")) (command "_.cannoscale" s) (command "_regenall") (princ)))
Thanks for the tips too.
