LT2024 Lisp help - How to link a "text" to the "save function"
cad1Q2LPX
Observer Observer
cad1Q2LPX
Observer
Observer
Hi everyone, we have Autocad LT and we need to link a "text" on to a layout to the "save function", a sort of "incremental number".
I mean :
text 00 -> saved file 01/03/2024
text 02 -> saved file 02/03/2024
Do you have ever tryed it ? If yes, how could we do ?
[ The subject line of this post has been edited for clarity by @pendean Original: Mr. Lou ]
scot-65
cad1q,
One method involves
1. Register an application and embed extended data onto a MText object (object must first exist in the file).
2. Command reactor to "sniff out" SAVE or QSAVE.
Hunt down the object(s) that has the extended data.
I am suggesting using MText so that one can append DFX 1 with "\P" new line.
;;Add extended data
(if (setq d (entsel "\nSelect text object: "))
 (progn
  (if (not (tblsearch "appid" "My_MenuApp")) (regapp "My_MenuApp"))
  (entmod (append (entget (car d)) '((-3 ("My_MenuApp" (1000 . "SaveDates"))))))
 );progn
);if
;;Fetch the object
(if (setq s (ssget "x" '((-3 ("My_MenuApp")))))...
Another method I can think of is using a multi-line attribute block (untested here).
Fetching the object involves stepping thru a list of anonymous blocks until the block is found.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
