I am looking for a lisp to generate hatch for multiple polygon separately?
giscivil92
giscivil92
Hi Everyone
I am looking for a lisp to generate multiple hatch for multiple polygons  separately?
ВeekeeCZ
Is there some issue you need to help with?
hak_vz
(defun c:mhatch (/ ang do-it doc hatch oname pname scl space ss)
	(if (setq ss (ssget '((0 . "LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
		(progn
			(setq
				scl (getvar 'hpscale)
				ang (getvar 'hpang)
				pname (getvar 'hpname)
				hpassoc (if (= (getvar 'hpassoc) 1):vlax-true :vlax-false)
				doc (vla-get-activedocument (vlax-get-acad-object))
				space (if (= (getvar 'cvport) 1) (vla-get-paperspace doc) (vla-get-modelspace doc))
			(vlax-for ent (vla-get-activeselectionset doc)
				(setq
					do-it nil
					oname (strcase (vla-get-objectname ent))
				(cond
					((vl-string-search "CIRCLE" oname)(setq do-it t))
					((and (vl-string-search "LINE" oname)(eq (vla-get-closed ent) :vlax-true))(setq do-it t))
					((equal (vlax-curve-getstartpoint ent) (vlax-curve-getendpoint ent) 1e-6)(setq do-it t))
				(if do-it
					(progn
						(setq hatch (vlax-invoke space 'addhatch acHatchObject pname hpassoc))
						(vlax-invoke hatch 'appendouterloop (list ent))
						(vlax-put hatch 'patternangle ang)
						(vlax-put hatch 'patternscale scl)
						(vla-evaluate hatch)
	(princ)
Miljenko Hatlak
Kent1Cooper
Can't you just use the regular Hatch command, and in its dialog box, check this option?
Kent Cooper, AIA
ronjonp
@giscivil92 Also look into the HPSEPARATE variable. Code is not needed for this task.
giscivil92
@Kent1Cooper Hello Kent thanks for sharing, actually I didn't know about this capability in Autocad, that's it I need
Thanks again
