LSP: Substitute out 'vl-filename-base' from a LISP command
jonnyhyoung
jonnyhyoung
I'm working on a LISP that in part needs to grab the filename (without extension) for a command - I managed to do this using 'vl-filename-base' but since it needs to run in acoreconsole it can't use anything from the VL Library. Is there any way to either remove ".dwg" or remove the last 4 characters from a string in only vanilla LISP?
Here's what I've got so far
(defun C:PlotToLocation (/ filename)
      (vl-load-com)
    (setvar "cmdecho" 0)
      (setq filename (vl-filename-base (getvar 'dwgname)))
      (setq filename (strcat "A:\\X\\Y\\" (vl-filename-base (getvar 'dwgname))".pdf"))
This sets the filename to "A:\X\Y\filename.pdf"
I can currently get "A:\X\Y\filename.dwg.pdf" but since the PDFs have to follow a naming standard, I need a way to remove the ".dwg".
Kent1Cooper
That function returns it without the ".dwg" for me:
But if somehow you're getting it with the ".dwg" included, you can strip that off this way [among others]:
(substr "YourFile.dwg" 1 (- (strlen "YourFile.dwg") 4))
"YourFile"
["YourFile.dwg" can be substituted with a variable name containing it.]
Another way:
(vl-string-subst "" ".dwg" "YourFile.dwg")
"YourFile"
Kent Cooper, AIA
ronjonp
Another way:
(cadr (fnsplitl "A:\\X\\Y\\filename.dwg"))
ronjonp
@jonnyhyoung You have answers HERE too where you cross posted.
jonnyhyoung
Yeah I posted in both forums as I generally lurk on both haha. Ended up going with
(substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4))
 Thanks everyone
