Looking for LISP to delete a specific attribute
Hans_Knol
Hans_Knol
Hi all,
I'm looking for an LISP routine that search in a drawing for a specific block named "VT0004" and remove the attribute "TAG1" or "TAG1F". Those attributes are in the block but are hidden.
Hope someone is able to create something.
Hans Knol
Moshe-A
@Hans_Knol  hi,
to remove hidden attributes you can ATTSYNC (or BATTMAN + sync)  the block
Moshe
hak_vz
Here is @Lee_Mac 's code for deleting invisible attributes. Hope it works.
;;; By Lee-Mac http://www.theswamp.org/index.php?topic=36280.0
(defun delInvisAtts ( bname ) (vl-load-com)
(if (tblsearch "BLOCK" bname)
(vlax-for obj
(vla-item
(vla-get-blocks
(vla-get-activedocument (vlax-get-acad-object))
bname
(if (and (eq (vla-get-objectname obj) "AcDbAttributeDefinition")
(eq (vla-get-invisible obj) :vlax-true)
(vla-delete obj)
(defun c:DIA ( / bn )
(delInvisAtts (setq bn (getstring t "\nBlock Name: ")))
(vl-cmdf "_.attsync" "_N" bn)
(princ)
Miljenko Hatlak
Simon_Weel
Like @Moshe-A says - you probably don't need a LISP routine to get rid of them attributes. Just sync (ATTSYNC) the block and they'll be gone.
Only Attribute Definitions are part of the block definition. When you insert the block, the attribute values are stored with that block insert. If you make changes to the block definition and delete some Attribute Definitions, then the values of those Attribute Definitions already in the drawing will not be deleted right away. Only if you use ATTSYNC, AutoCAD will replace / update the attributes in blocks already placed.
devitg
@Hans_Knol despite the block name is VT00004 and not VT0004 , it only had TAG1F  invisible att.
I use the DIA Lee-mac and it erase the TAG1F att , find attached dwg result
