Looking for examples and documentation of (ade_oddefinetab (ade_odtablelist...
Hello everyone,
I have spend many hours looking for examples and documentation of
(ade_oddefinetab
(ade_odtablelist
(ade_odaddrecord
(ade_odsetfield
and everything related to it
The best thing I found it was
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/objectdata-in-map-3d/td-p/3072564
So, if someone has better links to indicate I'll be glad
Thanks in advance + regards
Lzucco
reinaldo_togores
Hi, I wrote something about this, but it is in spanish. It includes a small example in which the code I suppose can be understood.
http://www.togores.net/vl/herramientasparasistemasdeinformaciongeografica/clasificacion-de-las-entid...
Hope this helps...
Regards.
CodeDing
@Anonymous ,
See attached documentation. I don't recall where I found it originally, but it's VERY useful and explains functions and provides examples.
Best,
~DD
cadffm
The PDF is a print of "AutoCAD Map 3D 2009 AutoLISP Reference" and is the content of the official autodesk help.
I am NOT an MAP3D User, so i don't know about the normal [F1]Help today, but you can find the acmaplisp.chm file as part of the Map 3D API References up to version 2012 from here: Map 3D Help Documentations https://knowledge.autodesk.com/support/autocad-map-3d/getting-started/caas/simplecontent/content/map... and additional informations perhaps however from AutoCAD Map Developer Center https://www.autodesk.com/developer-network/platform-technologies/autocad-map-3d
Sebastian
Thanks!
May you share a call examples for the functions DEFINETABLA and REGISTRO?
Regards
These are my attempts without success.
------- Test1.lsp
results on
T
(("Tablename" . "UPSDF") ("TableDesc" . "UP CONECTOR") ("Columns" (("ColName" . "altura") ("ColDesc" . "altura edificação") ("ColType" . "Integer") ("DefaultVal" . 9.0))))
 but Autocad Civil 3D 2019 freezes ???
I can use VLIDE (Visual List Editor) but at Autocad Model the mouse pointer is off
------ Test2.lsp
I got an error because a wrong syntax on calling the function
Help!
Maybe I found a solution...
For anyone interested check attached file test1.lsp (did not freezes Autocad Model Space)
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/map-query-through-lisp/td-p/2235108
(setq ade_cmddia_before_qry (getvar "cmddia"))
(setvar "cmddia" 0)
(mapcar 'ade_dwgdeactivate (ade_dslist))
After using any ADE_OD commands run
(setvar "cmddia" ade_cmddia_before_qry)
