call dynamic blocks from another file by autolisp
Hi guys, i am working in autolisp and i need to instantiate dynamic blocks that are in file "BLOQUES DINAMICOS 1.dwg" and put them in new file "prueba.dwg", i have to do this with autolisp in visual LISP.
There are some dynamic blocks (figures with blue color) in image, for example, the name of the second figure is "DIM.conexion mt y bt", i would like to put this in "prueba.dwg". I thank the person who can help me.
I know there is information about it but it does not work for me. Thank you so much if you can help me
DannyNL
This sounds like a one time job and it will probably take more time to program something than to use the standard functions AutoCAD already offers (WBLOCK, Design Center, ToolPalettes).
I.e. please check link below how to get blocks from another drawing to your current one with the Design Center.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoC...
