Looking for a LISP to attach current drawing/open drawing to email
Jason.Rugg
Message 1 of 12
Jason.Rugg
I am looking for a simple LISP that will start an new outlook email message and attach the current/active drawing file that is open.
Replies (11)
Message 2 of 12
doaiena
Message 3 of 12
Jason.Rugg
@doaienaThat does not work, it errors out with "too many arguments".
Message 4 of 12
doaiena
It worked for me like this:
(rjp-OutlookMessage "mail@mailserver.com" "Test Email" '("C:\\Drawing1.dwg") "Nothing to read here :)" T)
Your are probably feeding too many arguments to the function.
Message 5 of 12
CodeDing
It worked for me also.
Message 6 of 12
Jason.Rugg
@doaiena @CodeDing I've tried it on multiple computers now, it fails on every one of them. Can either of you do a screencast showing the code and how you are using it?
Message 7 of 12
CodeDing
@Jason.Rugg ,
I can't screencast, but when I paste this code into a dwg (with appropriate input changes) then run "TEST" it pops up the email (have also tested w/ sending it).
Do you have Outlook? Mac/PC?
(defun c:TEST ( / )
  (defun rjp-OutlookMessage
         (To Subject AttachmentList Body Send / objMail objOL)
    (if (and (setq objOL (vlax-get-or-create-object "Outlook.Application"))
	     (setq objMail (vlax-invoke-method objOL 'CreateItem 0))
      (progn
        (vlax-put objMail 'To To)
        (vlax-put objMail 'Subject Subject)
        (vlax-put objMail 'Body Body)
        (foreach file AttachmentList
  	  (vl-catch-all-apply
	    'vlax-invoke
	    (list (vlax-get objMail 'Attachments)
		  'Add
		  file
        (if send
 	  (vlax-invoke objMail 'Send)
	  (vlax-invoke objMail 'Display :vlax-true)
        (vlax-release-object objOL)
        (vlax-release-object objMail)
    (princ)
(rjp-OutlookMessage
  ;;email address (multiple separated by semicolon)
  "myemail@myemail.com"
  ;;Subject
  "Test Email"
  ;;Attachments as a list of strings
  '("C:\\users\\myusername\\desktop\\test.dwg")
  ;;Text in body of email
  ;;nil will open email to edit...T will send email in the background
  nil ;<- I have tried this w/ nil and t successfully
);defun
Best,
~DD
Message 8 of 12
ronjonp
I don't use Outlook anymore but try calling like this:
(rjp-outlookmessage
  "Test Email"
  (list (strcat (getvar 'dwgprefix) (getvar 'dwgname)))
  (strcat "Hello Client, Please see attached drawing: " (getvar 'dwgname))
  nil
Message 9 of 12
Jason.Rugg
@CodeDingOk this is actually halfway working, it will at least open a pre-filled/blank email but it does not attach the active drawing file that the command was called out in. I'm not the most versed in LISP and coding.
Message 10 of 12
CodeDing
@Jason.Rugg ,
For that, you will use @ronjonp 's elegant method.
Here it is incorporated with a check to be sure your dwg has already been saved.
(defun c:TEST ( / txt)
	     (setq objMail (vlax-invoke-method objOL 'CreateItem 0)))
      (progn
  	  (vl-catch-all-apply 'vlax-invoke
			      (list (vlax-get objMail 'Attachments) 'Add file))
        );foreach
        (if send
        );if
      );progn
    );if
  );defun
(if (= 1 (getvar 'DWGTITLED))
  (progn
    (rjp-outlookmessage
      "Test Email"
      nil
    (prompt "\nEmail Created.")
  );progn
;else
  (progn
    (setq txt "Drawing has not been saved. Please save and try again.")
    (prompt (strcat "\n" txt)) (alert txt)
  );progn
);if
(princ)
);defun
Best,
~DD
Message 11 of 12
Jason.Rugg
@CodeDingWith some modifications I was able to get this to work well enough for my needs. Thank you.
Message 12 of 12
CodeDing
@Jason.Rugg ,
I fell you should credit @doaiena  and @ronjonp  for their relevant and direct contributions to the solution.
