Looking for a Lisp substitute all textstyles to a specific ttf
Hans_Knol
Hans_Knol
Hi all,
I'm looking for a lisp routine that will be change all textstyles in the drawing sustitute from a shx to a ttf, for ex. changing it to Arial.ttf
Hope someone have a tool for this.
Hans
Hans Knol
dbroad
Here is a sample. To use it, you should wrap it in a defun with a command name you select.  The values in the setfont method would depend on the font you want to use.  If using other than arial, use the style command to create the style and then use the getfont method to determine the appropriate setfont settings for automation. Read more about the setfont file in the activex help docs.
(vlax-for n (vla-get-textstyles
	      (vla-get-activedocument
		(vlax-get-acad-object)))
    (vla-setfont n "arial" :vlax-false :vlax-false 0 34)
seect
Architect, Registered NC, VA, SC, & GA.
hak_vz
Try this
(defun c:change_all_textstyle_font ( / newfont doc)
	(setq newfont (getstring T "\nEnter new font for all text styles >"))
	  (vlax-for style (vla-get-textstyles (setq doc (vla-get-activedocument (vlax-get-acad-object))))
		(vla-put-fontfile style newfont)
	(vla-regen doc acactiveviewport)
Font name: Arial.ttf   Times.ttf  Century.ttf  or look for file name in C:\windows\fonts by right click and properties
Miljenko Hatlak
Kent1Cooper
There's another topic [if not more than one] about this, which has different code to do the same thing, but also has a >suggestion you might want to consider<.
Kent Cooper, AIA
