Login and password with startapp function - LISP
Hi, Is it possible put to the window login and password using "startapp" function to start windows application?
MK
Moshe-A
@Anonymous hi,
as far as i know there is no build-in  password method in AutoLISP but you can start your command by pausing to ask a user name/password than call (stratapp)
if you defun a dialog box there is a dcl attribute called "password_char" but this is only for concealing the password on the dialog.
moshe
Yes, but how to put name/password to the window witch appears after using startapp?
Moshe-A
after or before?
provide more info?  what application are we talking?
OK, step by step
1. (setq login (getenv "USERNAME")) ;I have my login.
2. (setq password "1234") ;I have my password
3. (startapp "C:\\...") ; appears window (external application - not in AC) with fields "login" and "password" and buttons OK and CANCEL.
4. ...this step I need put login and password but automatically from variables login and password. Is it possible?
Moshe-A
well, the (startapp) function works much like calling an application from the cmd window (remeber DOS?)
e.g if the external application accepts arguments?  then you can provide them .
here the function format:
(startapp appcmd [file])
the [file] argument can be replaced with arguments (it's a string)
if the application you are calling does not have command arguments then you can not pass arguments to it.
moshe
OK, Thanks.
