- Mute
- Permalink
- Report
Code: http://www.lee-mac.com/incrementalarray.html
Hi Everyone,
It seems like it should be simple to do this, but maybe not. Does anyone know how to modify the Dynamic Incremental Array to end with allowing the user to place one final object freely?
For example: select objects to array -> incarrayd -> input offset value -> pick basepoint - > array objects -> then you can place one more using the original basepoint.
Most of the time I use this command the final object to be placed isn't evenly spaced with everything else.
Thank you
