List of visibility states does not work with all blocks
r_de_nier
r_de_nier
With this peace of code I want to get the visibility states in a list. It works fine with some blocks, but not with others.
The blocks looks the same to me, but I can not find out why it does not work with all blocks.
This is the code and in the attachment I have a drawing with to almost similar dynamic blocks.
One will work and the other one gives nil.
(defun c:lv (/ list_visi)
      (if (and (setq blk (car (entsel "\nSelect Dynamic block with Visibility State :")))
         (= (vla-get-isdynamicblock (setq blk (vlax-ename->vla-object blk))) :vlax-true)
  (progn
    (setq props (vlax-invoke blk 'getdynamicblockproperties))
    (foreach prop (vlax-get (car props) 'allowedvalues)
      (setq list_visi (cons (list prop) list_visi))
  (setq list_visi (reverse list_visi))
komondormrex
to get visibility states  of a visibility property you need to specify one. that is "Visibility1"  in your particular case.
	(if (and (setq blk (car (entsel "\nSelect Dynamic block with Visibility State: ")))
  	(if (vl-some '(lambda (dyn_property) (= "Visibility1" (vla-get-propertyname (setq vis_property dyn_property))))
    	(vlax-get vis_property 'allowedvalues)
r_de_nier
 Again you are my hero. How on earth could I figure this out by my self? I'm used to the non VL calls.
Slowly I get the hang of it, but most of the times I got stuck.
Thanks again!
ВeekeeCZ
@r_de_nier wrote:
...How on earth could I figure this out by my self? I'm used to the non VL calls.
So it seems that the issue is not so much vl-functions but basic foreach.
(defun c:lv (/ list_allowedvalues)
    (foreach prop (vlax-invoke blk 'getdynamicblockproperties)
      (foreach allowedvalue (vlax-get prop 'allowedvalues)
	(setq list_allowedvalues (cons allowedvalue list_allowedvalues)))))
  list_allowedvalues
In this case this works because no other property but the visibility has "allowedvalues"
