Elevation difference
k005
Advisor Advisor
Message 1 of 16
k005
Hello friends;
How can I get the elevation differences of the objects I have given in the sample drawing (2 separate objects) on the command line?
Thanks in advance to the helpful friend.
Accepted solutions (3)
Replies (15)
Message 2 of 16
Kent1Cooper
There are no elevation differences -- everything's at Z=0.  Do you mean you want to get the numerical difference between the content of two Text objects, or Attributes?
Kent Cooper, AIA
Message 3 of 16
komondormrex
for blocks
(abs (- (atof (getpropertyvalue (car (entsel "\nPick block 1: ")) "1950.550")) (atof (getpropertyvalue (car (entsel "\nPick block 2: ")) "1950.550"))))
for texts
(abs (- (atof (getpropertyvalue (car (entsel "\nPick text mark 1: ")) "textstring")) (atof (getpropertyvalue (car (entsel "\nPick text mark 2: ")) "textstring"))))
Message 4 of 16
k005
Yes. I definitely mean the numerical difference. My goal is to make the attribute process even if it is a block or text.
Message 5 of 16
k005
Thanks. How can we combine these codes in a single select object?
Message 6 of 16
k005
The result of both selections should be: 2.60.
Atr.Block in some projects. In some, it is just text.
My goal is to be able to do this in a single routine.
Message 7 of 16
komondormrex
maybe like that
(defun c:get_elev_difference (/ elevation_offset_sset ename_1 ename_2)
 	(prompt "\nPick 2 entities with marked elevation offset.")
 	(setq elevation_offset_sset (ssget '((0 . "insert,text"))))
 	(if (and elevation_offset_sset
 			  (= 2 (sslength elevation_offset_sset))
 		 (abs (- (if (= "INSERT" (cdr (assoc 0 (entget (setq ename_1 (ssname elevation_offset_sset 0))))))
 					(atof (getpropertyvalue ename_1 "1950.550"))
 					(atof (getpropertyvalue ename_1 "textstring"))
 				 (if (= "INSERT" (cdr (assoc 0 (entget (setq ename_2 (ssname elevation_offset_sset 1))))))
 					(atof (getpropertyvalue ename_2 "1950.550"))
 					(atof (getpropertyvalue ename_2 "textstring"))
		 (progn
		 	(princ "\nInvalid selection")
			(princ)
Message 8 of 16
k005
Ok. Thank you very much, well done. 🤗
Message 9 of 16
k005
Hello
How can we make this lisp code capable of processing texts such as 4+382, 4+391?
 @komondormrex
Message 10 of 16
komondormrex
hey there,
try this one
	(arxload "geomcal.crx")
 					(cal (getpropertyvalue ename_1 "1950.550"))
 					(cal (getpropertyvalue ename_1 "textstring"))
 					(cal (getpropertyvalue ename_2 "1950.550"))
 					(cal (getpropertyvalue ename_2 "textstring"))
		 (progn
			(princ)
updated
Message 11 of 16
k005
Thank you buddy. ‌🤗 internet connection was very slow. Now I can write...
Message 12 of 16
k005
@komondormrex
sometimes I get this error.
; error: no function definition: CAL
I had this working. but right now it's not working. I wonder what is the reason?
I think I should run the Cal command first in Command... then it works
Message 13 of 16
komondormrex
geomcal.crx got unloaded. check update or load cal manually (arxload "geomcal.crx").
Message 14 of 16
k005
Ok. I understood thank you.
There is only one problem:
5+800.00
4+195.00
In texts like this, it only gives the difference as 606. However, the correct result (according to this process) should be 1606. How do we organize this?
sometimes even ;
KM 5+800.00
KM 4+195.00
It can also be like...
Message 15 of 16
komondormrex
for these check the following code
	(defun string_number (string)
		(if (vl-string-search "+" string)
			(setq string (vl-string-subst "" "+" string))
		(if (vl-string-search "KM" string)
			(setq string (vl-string-subst "" "KM" string))
		(atof string)
					(string_number (getpropertyvalue ename_1 "1950.550"))
					(string_number (getpropertyvalue ename_1 "textstring"))
					(string_number (getpropertyvalue ename_2 "1950.550"))
					(string_number (getpropertyvalue ename_2 "textstring"))
		 (progn
			(princ)
Message 16 of 16
k005
Thank you very much. Ok. 🤗
