List more drawings in File menu?
Message 1 of 16
Can anyone tell me how to increase the number of drawings available in the
drawing history shown at the bottom of the File menu? I'm using r14, win95.
Thanks.
Randy Walton
Replies (15)
Message 2 of 16
Nope. It's a hard-coded limit.
__
RWalton wrote in message
news:801kja$k5r8@adesknews2.autodesk.com...
> Hi,
the
win95.
Message 3 of 16
I've seen several such utilities mentioned from time to tim in this
newsgroup. I'm sure you can find something over at www.dotsoft.com or
www.manusoft.com. However I'm currently developing an MRU utility for
AutoCAD 2000. It allows unlimited entries and even lets you remove entries.
Rather than being located under the file mnu, it sits in a dockable window.
If you would be interested in helping me debug, I can mail a copy to you.
BTW, that invitation goes out to everyone in this newsgroup. If you want
more details, email me at foquendo@hotmail.com
> Hi,
win95.
> Thanks.
> Randy Walton
Message 4 of 16
Frank,
In R14 you could also use DOSLIB's registry set and get functions to
write out the current drawing name (from a function in acad.lsp) to
one of a set of registry keys, then read them back and plop the list
into a simple DCL dialog. hmmm....
details to follow....
Matt
stachoni@bellatlantic.net
On Sat, 6 Nov 1999 12:19:04 -0600, "Frank Oquendo"
>> Hi,
>win95.
>> Thanks.
>> Randy Walton
Message 5 of 16
True but I prefer the new modeless dialogs A2K offers.
Message 6 of 16
Well, yeah, obviously, but I was suggesting this for those people
still on R14 (of which there are many).
Matt
On Mon, 8 Nov 1999 08:47:30 -0600, "Frank Oquendo"
Message 7 of 16
Terry Dotson already has an extended MRU in DCL. You can check it out at his
web site: http://www.dotsoft.com
Matt Stachoni wrote in message
news:Cv8mOMuUs47hLkmw5KnXyRfKL2lF@4ax.com...
> Matt
Message 8 of 16
Matt,
I have an idea that if you could manage to stuff the values into the
correct registry section (hive?), Acad might(?) just pick them up and
display them, available for picking (?). Unfortunately, this doesn't
seem possible with either dos_regset or the (undocumented but still
available, in R14) native Acad setenv, as they are only able to write
to their own (hard-coded) hives.
Fire up regedit & have a look around...
Oh, Owen?
hm
Message 9 of 16
Herman:
>Oh, Owen?
You called?
I've already investigated that angle. Unfortunately, AutoCAD has a fixed
internal limit (it contains four static buffers for storing the MRU files)
so no amount of registry tweaking will change anything. It would only take
10 to 15 minutes for an Autodesk programmer to increase the limit, so that
is really where our efforts should be directed. 🙂
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
Message 10 of 16
Herman,
You can get around Autodesk's built-in limitations by using DOSLib's
(dos_regset) and (dos_regget) functions - they write keys\values to
the HKey_Current_User\Software\Doslib section (by default), which has
the double effect of (a) allowing you as many dwg's to register as you
wish and (b) having the list be "owned" by the user's profile. It's
great if you are also incorporating roaming profiles from an NT
Server, because whenever the person logs on to any machine the correct
dwg. history pops up.
And you need to be careful about using (getenv) and (setenv) to read
registry values, as I think they are cached and flushed at drawing
exit. In R14 anyway, it can cause problems with numerous sessions
open.
Matt
On Mon, 08 Nov 1999 19:23:23 PST, Herman Mayfarth
wrote:
>Matt,
>Oh, Owen?
> hm
Message 11 of 16
OK. At least we know...:)
hm
Message 12 of 16
Matt,
numerous sessions
> open.
Thanks for the heads up. I haven't really used
(setenv), yet, only verified that it does write
to the registry, & found its hive. I'll keep an
eye out for screwy behavior.
hm
Message 13 of 16
What modeless dialogs A2K offers? 🙂
Message 14 of 16
The Properties window and the Design Center are examples of modeless windows
Vladimir Nesterovsky wrote in message
news:382d4a1d.3101671@adesknews.autodesk.com...
Message 15 of 16
Yes, but how the programmer can use them?
If you're talking MFC, I think it was
possible in r14 also.
On Tue, 9 Nov 1999 11:48:11 -0600, "Frank Oquendo"
Message 16 of 16
I use Jorge Lopez's Dockable Container control (A2K only). If you want to
check it out, look for ACCONT v1.1 in the Customer Files NG.
news:382aad2d.28465215@adesknews.autodesk.com...
