David,
Valid only for north-america area...
If you sell anywhere else, lets say in Europe, each copy has its one
hardlock and if you want to use all five copies you must install all 5
copies, because their serial number and hardlock are conected...
There is a posibility to use the same hardlocked copy on all five machines,
but not in the same time, if you use a single network licence...
Marius
David Doane wrote in message
news:01bf28c8$1c5d25a0$e956d2d0@lms-1...
> Marius,
> > No, I have never heard two AutoCAD software products with the same
serial
> > number at diferent users... In fact this is Autodesk method to control
> the
> > licence users...
> If a company buys, say 5, copies of AutoCAD, and they register all 5 to
the
> CAD administrator or company owner, they can use 1 copy on five machines
> and put the other 4 on the shelf. It would be no different than
> reinstalling the same copy 4 times.
> When I was an Autodesk Reseller, I would preregister 50 copies, all
exactly
> the same, at one setting before even delivering them to the customer. I
> just created a DOS batch file utilizing a program called StacKey and ran
it
> on all of the primary diskettes.
> I realize that it cannot be done in exactly the same way today, but it can
> be done in a similar fashion.
> And that was all that I was commenting on. No more.
> Dave D
> (remove '-' for Email)
> Marius wrote in article
> <802kfk$mjc3@adesknews2.autodesk.com>...
serial
> the
> > licence users...
> > What is true is that if we are talking about a non hardlock protected
> > AutoCAD version, that can be easily passed from the licenced user to
> SOMEONE
> > ELSE, and your application uses for protection that serial number, than
> that
> > SOMEONE ELSE will be able to use your product with no licence...
> > In order to support my opinion regarding the necesity of using a
> sepparate
> > hardlock for your application in order to protect it against software
> > piracy, I want to remember you that Genius product (first written in
> lisp),
> > before it was bought by Autodesk, required a serial number, a hardlock
> and
> > an authorization code with many many characters...
> > And I have never heard anything about a cracked Genius version for
> AutoCAD
> > 12/13/14...
> > What is also true is that a company can use hardlocks with the same
> > characteristics, but they will manage their licences using different
> serial
> > numbers and also authorization codes...
> > Anyhow this discussion is valid only for significant aplications in
> > development area, when you realy need to protect your work... For small
> > customizing applications is perfectly valid what Reini said in his
> > message...
> > Marius
> > news:01bf2891$2c8bed80$4256d2d0@lms-1...
> > > I haven't been following this thread, but when counting on a serial
> > number,
> > > keep in mind that some companies use the same SN company wide, keeping
> the
> > > licensed copies on the shelf. At least that's the way it used to
work.
> > > I'm not sure about the last two releases, or site licensing.
> > > Dave D
> > > <801jt2$k6m3@adesknews2.autodesk.com>...
> > > > True, but some major incovenients may appear:
> > > > 1. This will make your application dependant on a certain user
> AutoCAD
> > > > serial number... User wil not be able to use the application on
> another
> > > > station with same version of AutoCAD, but different serial...
> > > > 2. You will not be able to offer free evaluation version to your
> users,
> > > for
> > > > a limited period of time...
> > > > 3. If somebody succeds in finding a cracked acad version, your
> > > application
> > > > personalized to that serial number can be already considered
> cracked...
> > > > Marius
> > > > Reini Urban wrote in message
> > > > news:382421a2.97187408@judy...
> > > > > a seperate hardlock is not required.
> > > > > either lock it to the serial number of the acad version:
> > > > > (getvar "_PKSER")
> > > > > or on locked versions (outside the US, with acad hardlock) lock it
> to
> > > > > this number:
> > > > > (getvar "_LINFO")
