List Manipulation
List Manipulation
avinash00002002
Message 1 of 22
List Manipulation
avinash00002002
Hi!
I have some lists one of them I am putting here for help.
original
(25 299.4 100.3 100.8 399.3 118.9 25)
convert to 0.5  precision
(25.0 299.5 100.5 101.0 399.5 119.0 25.0)
I want to convert to 0.5 but the total of all members in a list is 1069.5 but I need to convert in 1070.
final summation of list members shall be 0.0 not .5
avinash
Replies (21)
Message 21 of 22
Kent1Cooper
@avinash00002002 wrote:
... summation of list of members are 0.0 it will also adjust members value.
If the members of the list are all rounded to the nearest 0.5, and if the summation of those members comes to a xx.5 value, by what standard should it decide which of the members to adjust to make the summation to the nearest 0.0 [whole number]?  Presumably it would adjust only one, whether up or down, but there must be a determination of which one.
Kent Cooper, AIA
Message 22 of 22
calderg1000
Regards @avinash00002002
Try this code.
;;;___
(defun ssum (lst / j n dj nlst st)
  (foreach j lst
    (setq dj (- j (fix j)))
    (cond ((= dj 0.) (setq n j))
          ((< dj 0.5) (setq n (+ (fix j) 0.5)))
          ((> dj 0.5) (setq n (+ (fix j) 1.0)))
          (t nil)
    (setq nlst (cons n nlst))
  (setq st  (apply '+ nlst)
        ndj (- st (fix st))
  (if (= ndj 0.5)
    (setq st (+ st 0.5))
  (print st)
  (print (reverse nlst))
;;;___
(setq lst '(25 299.4 100.3 100.8 399.3 118.9 25))
(ssum lst)
;1070.0
;(25 299.5 100.5 101.0 399.5 119.0 25)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
