LIST FONT TYPE
LIST FONT TYPE
Message 1 of 8
LIST FONT TYPE
Dear good day, someone knows how to list all types of letters supported in autocad both .ttf and .shx. example: something like that: ( "C:\\windows\\font" "arial.ttf" "calibri.ttf" ....) ( "C:\\program files\ autodesk\autocad 2017\\fonts "romans.shx " "romand.shx"....)) Thank you very much.
Replies (7)
Message 2 of 8
m_badran
Hi,you can use lee-mac 's code and changed as below.
(LM:directoryfiles "c:/windows/fonts" "*.ttf" nil);for ttf files
(LM:directoryfiles "C:/program files/autodesk/autocad 2014/fonts" "*.shx" nil);for shx files
Change red color as your version.
HTH.
Message 3 of 8
Hi. The problem I have is that I need to know the name of a special font that uses AutoCAD, with the command STYLE I establish the font "Courier New" "Bold", and I would like to know what font name it uses, when I use The TBLSEARCH function to see the font name, does not show it, the value 3 is empty.
(tblsearch "STYLE" "Standard")
((0 . "STYLE") (2 . "Standard") (70 . 0) (40 . 0.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 0.2) (3 . "") (4 . ""))
In short, I need to know which font name AutoCAD uses in the combobox.
Example:
Arial - Regular -> arial.ttf
Calibri - Italic -> calibrii.ttf
Thanks.
Message 4 of 8
marko_ribar
Command: (setq e (tblobjname "STYLE" "Standard"))
<Entity name: 7ff7ea403910>
Command: (entget e '("*"))
((-1 . <Entity name: 7ff7ea403910>) (0 . "STYLE") (330 . <Entity name: 7ff7ea403830>) (5 . "11") (100 . "AcDbSymbolTableRecord") (100 . "AcDbTextStyleTableRecord") (2 . "Standard") (70 . 0) (40 . 0.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 0.2) (3 . "ARIAL.TTF") (4 . "") (-3 ("ACAD" (1000 . "Arial") (1071 . 34))))
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 5 of 8
m_badran
I think this helpful for you.
Message 6 of 8
The solution is perfect when you want to know the font of a font style, and if I wanted to get the list of fonts according to the styles shown in the combobox marked in red like image.
The list would be something like this:
The texts marked in red are an example of how the font styles would be listed.
(("arial.ttf -> regular" "ariali.ttf -> cursiva" ....)("romans.shx" "bigfont.shx -> check use big font"......))
This is possible?
Message 7 of 8
Ranjit_Singh
maybe something like this
(defun c:somefunc ( / a b c)
(acad_strlsort (while (setq a (tblnext "style" (null a)))
    (setq b (entget (tblobjname "style" (cdr (assoc 2 a)))))
    (setq c (cons (setq b (strcat (cdr (assoc 3 b)) " -> " (cdr (assoc 2 b)))) c))))
Message 8 of 8
That solution lists only the font styles created, but my question is if you can list all font styles according to the attached image in red color (combobox).
