list automation
list automation
Message 1 of 28
list automation
Dear Sirs,
I'm now starting to learn how to code lisps.
I need to create a process to read a polyline or 3dpolyline nodes coordinates and export them to a .xls file. I can do it using LIST command, but as i have a large number of examples i would like to optimize my work with a lisp.
Second Step:
Write the coordinates in this format:
poly[0][0] :=VEC(-10.3545,-1.9963,0);
poly[0][1] :=VEC(-10.3488,-1.8242,0);
poly[0][2] :=VEC(-10.3258,-1.6521,0);
Replies (27)
Message 21 of 28
Hi again,
I noticed that the code uses the UCS World coordinates, can i turn it into UCS local?
Message 22 of 28
Solved
Message 23 of 28
pbejse
@Anonymous wrote:
Solved
Well good for you then @Anonymous .
Is that for both additional option?
- Outer line is always counter clockwise, inner line is always clockwise.
- can i turn it into UCS local?
Would you mind post and share the added feature so we would understand what you were asking in the last two posts?
Message 24 of 28
None of them are solved. But the second post is not relevant at the moment.
The first post is still alive for you experts. Appreciate your help
Message 25 of 28
pbejse
@Anonymous wrote:
The first post is still alive ...
So what;s the deal with this then
Will that be the user is prompted to select two at a time? The outer and the inner line?[0][#] is the outer and [1] [#] as the innner coordinates?
Or this has nothing to do with the previous request?
Message 26 of 28
Exactly, the perfect lisp should get/ask 2 types of coordinates in 2 different objects:
Counter clockwise:
poly[0][0] :=VEC(x,y,x);
Clockwise:
poly[1][0] :=VEC(-x,y,z);
poly[1][1] :=VEC(-10.3488,-1.8242,0);
Message 27 of 28
pbejse
Let's say there are 6 pairs of outer/inner polylines, on the drawing? are you wanting 1 file per pair? and the filename would increment by 1 "DrawingName_1.csv"  "DrawingName_2.csv" ?
If thats the case, we add a loop for the user to select one pair after another. The number will always be
[0][0] for Counter clockwise and [1][0] for clockwise: ?
Post a sample drawing.
Message 28 of 28
Let's get it simpler. The outer rectangle is solved with the lisp you gave me on the first posts, so let's forget it.
Now i need another lisp (similar to the last one) that write the nodes in clockwise. --> format [1][#]
Thank you again
