List all visible Toolbars
scot-65
Advisor Advisor
scot-65
I'm trying to build a list of all visible toolbars on the UI.
What I have so far does not seem to do it.
I have tried vla-get-tagstring and vla-getname, and a few others without success.
 (setq b nil)
 (vl-catch-all-apply (function (lambda ()
  (vlax-for tbar (vla-get-toolbars (vlax-get-acad-object))
   (setq b (cons (vla-getname tbar) b))
(princ "\n b= ")(princ b)(princ)
The list can either be the toolbar name or it's Element ID.
Any help is appreciated.
Scot-65
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
hmsilva
HI scot-65,
perhaps something like this (untested)
(vlax-for mnu (vla-get-menugroups (vlax-get-acad-object))
   (vlax-for tlb (vla-get-toolbars mnu)
      (setq tlb_lst (cons (vla-get-name tlb) tlb_lst))
Hope this helps,
Henrique
scot-65
What you show are ALL the available toolbars, and yes, it works.
However, what I am looking for is the current visible ones.
The snippet I am adapting came from showing the
menu bar POPs via vla-get-menubar / vla-get-tagstring.
I'm looking for the equivalent for toolbars.
Scot-65
Scot-65
hmsilva
Visible ones... my bad...
      (if (= (vla-get-visible tlb) :vlax-true)
Hope this helps,
Henrique
scot-65
Oh, how sweet!
I do thank you for your help, hmsilva.
For future reference, the synopsis is as follows:
Our menu system swaps POPs and Toolbars in lieu of Workspaces
(if we used workspaces, there would be at least 20 of them and this menu was developed way back in R12 to R2004).
When opening a drawing, the Drawing environment is set and the
UI's POP and Toolbars are also aligned (for now).
For this to happen, a Dictionary "Gremlin" is introduced into the file.
To set the toolbars, the following code is used:
    (if (member (vla-get-name tlb) %TBNAMES%);is showing and a member of the list
     (vla-put-visible tlb :vlax-false)))
   (if (= (vla-get-name tlb) a)
    (vla-put-visible tlb :vlax-true))
Where %TBNAMES% is a LIST of all the "Custom" toolbar names to hide
and [a] is the toolbar that will display.
Scot-65
Scot-65
hmsilva
You're welcome, Scot-65
Glad I could help
Henrique
scot-65
I have this section of code as part of the S::STARTUP section and when
testing this code, the code is read but does not execute when SDI=1.
I had to wrap this code with a temporary SDI toggle in order for this to
execute.
How strange.
Scot-65
