list about to delete from layouts
Fleww
Fleww
Hi, is there any lisp for something like this. I want this red flaged area get deleted for every single layout, so i can make something new and use lisp to copy to multiple layouts so I can easy make work done. Is there something that can do it for me? I always needed things like this for work.
ВeekeeCZ
Try this.
3wood
You can also try this one
Sea-Haven
Maybe this
(defun delsqlay ( / tabs lay tabname)
(setq tabs (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object))))
(vlax-for lay tabs
  (setq tabname (vla-get-name lay))
  (if  (/= tabname "Model")
  (progn
  (setvar 'ctab tabname)
  (command "pspace")
  (command "erase" "W" "100,100" "250,250" "")
(princ)
(delsqlay)
paullimapa
Perhaps you should consider a different method of implementing the legend in your title block?
In the title block drawing include the legend in layers that can be frozen/turned off separate from the rest of the sheet.
Then xref attach or overlay the title block drawing file into layouts of drawings like the one you're showing.
Now any changes of the legend can be done in one drawing and that info is automatically reflected in every drawing that has it referenced into.
Paul Li
IT Specialist
@The Office
Fleww
love you ❤️ perfect!
Fleww
ty thats it ❤️
