Altering Lisp to prompt user to save files under their desire folder & filename
I came across with this lisp file online & i found its not perfect in the way that its won't allow me to save file into my desire folder & file name. Can someone please help to look at this lisp and change it? Thanks.
(vl-load-com)
;;-------------------=={ UnFormat String }==------------------;;
;; Returns a string with all MText formatting codes removed. ;;
;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;;
;; Arguments: ;;
;; str - String to Process ;;
;; mtx - MText Flag (T if string is for use in MText) ;;
;; Returns: String with formatting codes removed ;;
(defun LM:UnFormat ( str mtx / _replace rx )
(defun _replace ( new old str )
(vlax-put-property rx 'pattern old)
(vlax-invoke rx 'replace str new)
(if (setq rx (vlax-get-or-create-object "VBScript.RegExp"))
(progn
(setq str
(vl-catch-all-apply
(function
(lambda ( )
(vlax-put-property rx 'global actrue)
(vlax-put-property rx 'multiline actrue)
(vlax-put-property rx 'ignorecase acfalse)
(foreach pair
("\032" . "\\\\\\\\")
(" " . "\\\\P|\\n|\\t")
("$1" . "\\\\(\\\\[ACcFfHLlOopQTW])|\\\\[ACcFfHLlOopQTW][^\\\\;]*;|\\\\[ACcFfHLlOopQTW]")
("$1$2/$3" . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);")
("$1$2" . "\\\\(\\\\S)|[\\\\](})|}")
("$1" . "[\\\\]({)|{")
(setq str (_replace (car pair) (cdr pair) str))
(if mtx
(_replace "\\\\" "\032" (_replace "\\$1$2$3" "(\\\\[ACcFfHLlOoPpQSTW])|({)|(})" str))
(_replace "\\" "\032" str)
(vlax-release-object rx)
(if (null (vl-catch-all-error-p str))
str
(defun c:t2csv ( / ss fname obj objstr txtins x )
(setq ss (ssget '((0 . "*TEXT"))))
(if (/= ss nil)
(progn
(setq fname (open "C:\\EXPORT_TEXT\\text2csv.txt" "W"))
(repeat (setq x (sslength ss))
(setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(setq objstr (vla-get-textstring obj))
(setq txtins (vlax-get obj 'InsertionPoint))
(if (= (vla-get-objectname obj) "AcDbMText")
(setq objstr (LM:UnFormat objstr nil))
(setq objstr (strcat (rtos (car txtins) 2 3) "," (rtos (cadr txtins) 2 3) "," (rtos (caddr txtins) 2 3) "," objstr))
(write-line objstr fname)
(princ (strcat "\n" (rtos x 2 0)))
(close fname)
(alert "No text selected try again")
(princ)
