Lisp
Lisp
Message 1 of 9
Lisp
This lisp just modifies one title block in a drawing with multiple layouts. Could it be fixed to modify all title blocks in all layouts? (defun fix_title ( / ss blk atts tagname value ) ; place data into title block (vl-load-com) (setq ss nil) (setq ss (ssget "X" (list (cons 2 "STAMP")))) (if ss (progn (setq blk (vlax-ename->vla-object (ssname ss 0))) (if (safearray-value (setq atts (vlax-variant-value (vla-getattributes blk)))) (progn (setq atts (vlax-safearray->list (vlax-variant-value (vla-getattributes blk)))) (foreach att atts (setq tagname (strcase (vla-get-tagstring att))); tagname (setq value (vla-get-textstring att)); value (if (= tagname "DATE")(vla-put-textstring att "2016")) ); foreach ); progn ); if (command "_regen") ); progn ); if ); function (princ) ;(Fix_Title)
Replies (8)
Message 2 of 9
john.uhden
Your code is acting only on one entity, the first one in the selection set (ssname ss 0). You should act on ALL of the items in the selection set, as in...
(setq i 0) ; index
(while (< i (sslength ss)
(setq blk (vlax-ename->vla-object (ssname ss i)))
;; Take your action
(setq i (1+ i)) ; increment the index
) ; end while
John F. Uhden
Message 3 of 9
Thanks! Sorry, can not get it work! Would you place these lines for me in the routine: (defun fix_title ( / ss blk atts tagname value ) ; place data into title block (vl-load-com) (setq ss nil) (setq ss (ssget "X" (list (cons 2 "NAMN PÅ DITT BLOCK")))) (if ss (progn (setq blk (vlax-ename->vla-object (ssname ss 0))) (if (safearray-value (setq atts (vlax-variant-value (vla-getattributes blk)))) (progn (setq atts (vlax-safearray->list (vlax-variant-value (vla-getattributes blk)))) (foreach att atts (setq tagname (strcase (vla-get-tagstring att))); tagname (setq value (vla-get-textstring att)); value (if (= tagname "TAG I DITT BLOCK")(vla-put-textstring att "DITT VÄRDE")) ); foreach ); progn ); if (command "_regen") ); progn ); if ); function (princ) (fix_title)
Message 4 of 9
john.uhden
(defun fix_title ( / ss i blk atts tagname value )
   (vl-load-com)
   ;; (setq ss nil) DELETE <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
   (if ss
     (progn
       (setq i 0) ;;<<<<<<<<<<<<<<<<<<<<<<<<<<<<
       (while (< i (sslength ss)) ;;<<<<<<<<<<<<<<<<<<<<
           (progn
             (foreach att atts
               (setq tagname (strcase (vla-get-tagstring att))) ; tagname
             ); foreach
           ); progn
         ); if
         (setq i (1+ i)) ;;<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
       ) ; while  ;;<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
       (command "_regen")
     ); progn
   ); if
   (princ)
); function
(princ)
(fix_title)
In the future, please do not use the Quick Reply.  The regular Reply shows an icon in the menu ribbon to "Post Code" which is the only way to preserve indentation.  I had to copy, paste, and reformat your routine to make it legible (with indentation).  I hope this works for you.
John F. Uhden
Message 5 of 9
Thanks a lot! Bcount tells me there are more then one titleblock but the routine still fix just the first instance of that block! I do not get any error massages! Best regards A
Message 6 of 9
john.uhden
Then add a line after (ssget ...)
(princ (strcat "\nFound " (itoa (sslength ss)) " insertions."))
Maybe you just didn't see the others, maybe because they are in other layouts?
John F. Uhden
Message 7 of 9
Yes, there are several layouts each with a titleblock. But this lisp just handles the first layout! The routine now just tells me how many instances there are but handles just first layout! BR Akmah
Message 8 of 9
john.uhden
My mistake. That should be i not 0...
John F. Uhden
Message 9 of 9
Thanks a lot! Now it runs perfectly! BR
