Message 1 of 10
I need help, after I use the lisp below the file name in xref tab has change to small letter (like NEW_WrongName-Xref). It should be just like the original file name (like OLD_RightName-Xref).
Is it the lisp or the Autocad itself?
See the image below:
Thank you.
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
