Associate objects from a point to distance test and remove duplicates
Message 1 of 1
(defun sort_inobj ()
(setq x 0 inlis '() elis '()); The type will be needed later in the code.
(repeat (sslength ss)
(setq typ (strcase (cdr (assoc 0 (entget (ssname ss x))))))
(cond
 ((= typ "LINE")(get_llis_ins))
 ((= typ "LWPOLYLINE")(get_llis_ins))
 ((= typ "POINT")(get_plis_ins))
(setq x (+ x 1))
(princ)
(defun get_llis_ins ()
(get_vertex (ssname ss x))
(setq g 0)
(repeat (length ptlis)
(setq pt (nth g ptlis))
(setq inlis (append inlis (list pt)))
(setq elis (append elis (list (ssname ss x))))
(setq g (+ g 1))
(princ)
(defun get_vertex (ent)
(setq h 0 ena (entget ent) ptlis '())
(repeat (length ena)
(setq itm (car (nth h ena)))
(if (= itm 10)(setq ptlis (append ptlis (list (cdr (nth h ena))))))
(setq h (+ h 1))
(princ)
(defun get_plis_ins ()
(setq in (cdr (assoc 10 (entget (ssname ss x)))))
(setq inlis (append inlis (list in)))
(princ)
(defun associate_objects ()
(setq x 0 alis '())
(repeat (length inlis)
(setq in (nth x inlis))
(setq g 0 lis '())
(setq in2 (nth g inlis))
(setq di (distance in in2))
(if (and (< di 10.0)(= (member (nth g elis) lis) nil))(setq lis (append lis (list (nth g elis)))))
(setq g (+ g 1))
(setq alis (append alis (list lis)))
(setq x (+ x 1))
(princ)
Multiple associations are found for 6 locations, in this particular DWG, with 132 associations. I'm trying to understand how to Dial down this list to another list removing different occurrences. Any help would be appreciated, and thanks in advance!
Michael Luckett
Replies (0)
