- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Does anyone have a lisp that will turn off all "VP Freeze" layers while within the current viewport?
Thanks!
Thanks!
Yes, that's what I'm looking for.
I want to be able to create a layout, manage my layers in a viewport with VP Freeze. If i have to do any additional design or adjustments I want model space to reflect the same layers that are available in my paper space.
A little bit crazy, but ok (why you work with VPfreeze and not Freeze?)
VPMAX VPMIN also does not provide an acceptable workflow?
Note: All Layers which VPfreezed in one VP, set to OFF (="global" = in all spaces an viewports)
- is NOT the same view in Modelspace (if there are nested objects on that layers, in Blocks or XRefs)
[ Remember the difference On/Off - Freeze/Thaw for nested objects ]
And if you have more Vports, you change the displayed view also there.
;;; All VPfreezed Layer in current VP set OFF
(defun c:CurVPFRlaySetOFF (/ tmp)
(if (and
(zerop(getvar 'tilemode))
(< 1 (getvar 'cvport))
(foreach VP (mapcar 'cadr (ssnamex (ssget "_X" (list '(0 . "VIEWPORT")(cons 410 (getvar 'ctab))))))
(if (= (getvar 'cvport) (cdr(assoc 69 (entget VP))))
(foreach lay (vl-remove-if-not '(lambda(dp)(= 331 (car dp))) (entget vp))
(and
(setq lay (entget (cdr lay)))
(<= 0 (cdr(assoc 62 lay)))
(princ (strcat "\nLayerOFF: " (cdr(assoc 2 lay))))
(entmod (subst (cons 62 (* -1 (abs(cdr(assoc 62 lay))))) (assoc 62 lay) lay))
; simple Option to VPthaw this Layer in ALL VPorts; (command "_.VPLAYER" "_thaw" (cdr(assoc 2 lay)) "_all" "")
(princ "\nCurVPFRlaySetOFF only available in floating modelspace / inside a paperspace viewport")
(princ)
Sebastian
