LISP to swap to first layout as active layout
Joakim_Intec_SE
Joakim_Intec_SE
I've gotten a request from a client that all dwg:s are to be delivered with the first layout tab as the active. Given that each deliver can contain hundreds of dwg:s I would like to automate this if possible.
Seeing as tilemode set to 0 gives me the last used layout and ctab requires me to know the name for each dwg I assume that a lisp function is needed.
I'm assuming the function would work something like this:
  • Find out what is the name of the first tab
    • The first tab in this case would be the left most one in open dwg
  • Set the named layout as active
    • I assume you can just call CTAB with the name
How would a LISP code look to solve this?
Thanks in advance for any help!
Moshe-A
@Joakim_Intec_SE  hi,
The following function will return the name of the first layout.
to run it on pack of files you will need something like Lee Mac >> script writer <<
enjoy
Moshe
(defun get_first_layout (/ adoc AcDbLayout firstLayoutName)
 (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
 (vlax-for AcDbLayout (vla-get-layouts adoc)
  (if (= (vla-get-tabOrder AcDbLayout) 1)
   (setq firstLayoutName (vla-get-name AcDbLayout))
  (vlax-release-object AcDbLayout)
 ); vlax-for
 firstLayoutName
Sea-Haven
Not quite the request but similar task will go to any layout desired. Most software has a Goto option. If you change the 99 in code to say 999 it will go to last layout as hinted 100+ layouts.
