Lisp to set ucs and view
idigg-be
Message 1 of 9
idigg-be
so im trying to do it in action recorder, but i have failed.  wondering if lisp could do it instead....
basically the workflow im trying to consolidate is: ucsfollow to 1, setting the ucs to an object(which rotates the view), saving the ucs as "plan", and then turning ucsfollow off, and saving the view as "plan"(with no layer snapshot)
it seems pretty straightforward, but with action recorder i run into a problem when i try to save the ucs and/or view as plan if it already exists.  aka these are the commands i record:
ucsfollow
1
ucs
enter
ob
enter
(pauses for user input)
ucs
enter
save
enter
name of ucs(its the same all the time)
enter*****
-view
enter
save
enter
name of view(same all the time)
enter*****
*****- these are the points at which i run into issues, because if it exists, i have to record a Y and a enter to overwrite, but if i include a Y and and enter to overwrite and the named ucs/view doesnt exist in the drawing, i get an error.
Thanks all.  if this is possible via action recorder, im open to that solution as well.
Replies (8)
Message 2 of 9
Moshe-A
@idigg-be ,
here's this macro in lisp command called actMacro, copy and paste the following into a notepad document save it as actmacro.lsp than load it into (or drag it in) autocad drawing, invoke ACTMACRO.
enjoy
Moshe
(defun c:actMacro ()
 (command "._undo" "_begin")
 (setvar "expert" 5)
 (setvar "ucsfollow" 1)
 (command "._ucs" "_Object" pause)
 (command "._ucs" "_save" "plan")
 (setvar "ucsfollow" 0)
 (command "._view" "_save" "plan")
 (setvar "expert" 0)
 (command "._undo" "_end")
 (princ)
); actMacro
Message 3 of 9
Kent1Cooper
@idigg-be wrote:
.... i run into a problem when i try to save the ucs and/or view as plan if it already exists.  .... because if it exists, i have to record a Y and a enter to overwrite, but if i include a Y and and enter to overwrite and the named ucs/view doesnt exist in the drawing, i get an error. ....
If, when it exists, you intend to overwrite it anyway, then I suggest you simply Delete it at the beginning.
UCS / NAmed option / Delete option / give it the name.
If it exists, it will report that it Deleted one.  If it doesn't, it will simply report that it didn't find one with that name.  No error will result either way.  Then when you get to Saving a UCS under that name, it will never be there to cause it to ask whether to overwrite it.
Kent Cooper, AIA
Message 4 of 9
Sea-Haven
Do you need to save a view ? UCS R viewname plan.
Message 5 of 9
idigg-be
ohh, awesome, so expert mode, if im reading it correctly, essentially turns off the confirmations and if things exists, it overwrites them?  thats what i was missing.  thanks!!!!
Message 6 of 9
Kent1Cooper
@idigg-be wrote:
.... so expert mode, if im reading it correctly, essentially turns off the confirmations and if things exists, it overwrites them?  ....
Be careful.  It's not just "expert mode" as a monolithic thing, but has multiple possible settings, affecting varying degrees of what it turns off and/or overwrites.  Read about it in Help to be sure you're using a setting that gets you what you want.
Kent Cooper, AIA
Message 7 of 9
idigg-be
thanks.  i dont plan on using it, just looking to see what technique was used to get around the overwrite prompt.
one more question since im rusty with lsp's... if i wanted to invoke it using a different input... say "PV" (for plan view), what would i change?  the name of the .lsp file, or the actmacro behind defun, or the actmacro at the end?
Message 8 of 9
a_ayala9GVUU
I've attached a LISP that I created with Claude AI, that does exactly what is requested.
Message 9 of 9
karfung
U may try the 2 below LISP,
(DEFUN C:UU()(COMMAND "UCSFOLLOW" "1" "")(COMMAND "UCS")(PRINC))
(DEFUN C:UI()(COMMAND "UCS" "WORLD")(COMMAND "REGEN" "")(PRINC))
Thanks.
