- Mute
- Permalink
- Report
Dear community,
please, can someone create a LISP for saving current DWG in DWG-2018 format to a Project subdirectory (automatic, without path selection). I work always with the same Project directory structure (eg. Project1, Project2) locally or on the server. Each Project directory have always the same subdirectories structure:
Project1
- BOM
- DWG2018
- Mechanical
Project2
- BOM
- DWG2018
- Mechanical
My DWG (source file) for each Project directory is located in the corresponding subdirectory "Mechanical". The DWG-2018 must be saved in the related subdirectory "DWG2018" (Project directory). It may be that subdirectory "DWG2018" has not been created yet, the LISP should check that and possibly create a new one, before saving as DWG-2018.
Many thanks for your help in advance
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
