Lisp to replace block with another block
Manicbala
Message 1 of 23
Manicbala
I have tried the below lisp to replace the block "RR" with "Level".
(defun C:QW4 ()
((C:-BLOCKREPLACE) "RR" "level" ""))
{{ Command: QW4
Initializing...
Select the block to be replaced or [?/= (select object)]: }}
After enter QW4 command, its prompting to select the block instead of replacing. Please resolve this.
Bala
Bala
Replies (22)
Message 21 of 23
BL_Apex
So it appears that running INSERT and selecting the block from the folder it's saved in will prompt for "Redefine Block" but running -INSERT from the command line or LISP does not. Even though the block .dwg has been updated with a new definition and I'm specifically calling up that file location in the command line/LISP, AutoCAD is still inserting the old definition without asking if I'd like to replace the existing definition. I even tried copying the .dwg with the new block definition to a different file location and calling that up, but got the same result.
UPDATE: I figured it out. I realized what you were hinting at is that it needs to be formatted as:
(command "-insert" "BLOCKNAME=filelocation/BLOCKNAME.dwg" ...)
Thanks.
Message 22 of 23
Had a similar issue with replacing a block.  This piece of code helped me greatly.
Message 23 of 23
ChicagoLooper
BLOCKREPLACE Command..
Express Tools Tab=>Blocks Panel=>Replace Block Icon
Chicagolooper
