undefine \ redefine AutoCAD standard commands
Moshe-A
Mentor Mentor
Message 1 of 10
Moshe-A
Hi Guys,
Many of us here knows that one can undefine\redefine an AutoCAD standard commands but still can be invokes by using the dot prefix. lately i encounterd some applications that disbales standard AutoCAD commands totally
i mean even trying to invoke it with dot prefix. maybe it's an objectarx \ net application?
can someone here elaborate on this, can it be done with VisualLISP\ActiveX?
can a user temporary override this? (if he wants to invoke the native command)
thanks in advance
Moshe
Replies (9)
Message 2 of 10
scot-65
Perhaps check using ATOMS-FAMILY
then REDEFINE if not present in the
returned list of strings (using MEMBER)
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 3 of 10
john.uhden
Are you sure that they are AutoCAD commands, or maybe just command functions?
Otherwise, I don't get it.
Is the command DDATTE?
John F. Uhden
Message 4 of 10
Moshe-A
yes i very sure
the commands are purge, textedit, ddedit
Message 5 of 10
dgorsman
I believe it's possible in managed dotNET, where you monitor the CommandWillStart event, and veto the command.  While there is a similar reactor for LISP, I'm not certain you can actually stop the command from there.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 6 of 10
Moshe-A
thank you, can a user temporary override this, if he wants to invoke the native command.
Message 7 of 10
pbejse
@Moshe-A wrote:
... lately i encounterd some applications that disbales standard AutoCAD commands totally..
*Off-topic* [ related to ]
During these past two weeks, our office experience a weird behavior with Autocad 2017 [ and only in 2017 ],  native commands like Opensheetset does not work and even ctrl+4 won't even bring up the Shee Set Manager panel. and to top it off, drawing files won't even open at all.
We ended up using "Reset Settings to Default" any ideas?
BTW: It all started when one of the users started using Autocad 2018
Appreciate any help
Message 8 of 10
dgorsman
@pbejse - bundles would be my first thought.  While they may install from a specific version, they can be set to load in multiple versions.
Message 9 of 10
doaiena
The "CommandWillStart" reactor in lisp can intercept a command and execute your own custom code before it, but it can't redefine/veto the command within the same event.
The AutoLisp reactor works like this:
(command "._LINE")
(Place your code here:)
(Continue execution of "._LINE")
You can also exit the current command within your code and execute another one in its place:
(defun ReactorFun (Reactor lst)
 (if (= (car lst) "LINE")
 (progn
 (vla-SendCommand (vla-get-activedocument (vlax-get-acad-object)) "(command) ")
 (alert "Execute custom command here")
(if (not CommandReactor)
 (setq CommandReactor (vlr-command-reactor nil '((:vlr-commandWillStart . ReactorFun))))
Message 10 of 10
pbejse
Thank you dgorsman, I will look into that.
