Lisp to Remove Points from blocks
AutoBIx
Message 1 of 8
AutoBIx
I'm Searching a lisp to remove the points (nodes) inside thousands of blocks (made by exported drawings).
i would like to remove them not turn them off with variable as show in many posts.
thanks a lot
Replies (7)
Message 2 of 8
ronjonp
Try this:
(defun c:foo (/ a d)
  ;; RJP » 2020-12-02
  (vlax-for l (vla-get-layers (setq d (vla-get-activedocument (vlax-get-acad-object))))
    (cond ((= -1 (vlax-get l 'lock)) (vlax-put l 'lock 0) (setq a (cons l a))))
  (vlax-for b (vla-get-blocks d)
    (if	(= 0 (vlax-get b 'isxref) (vlax-get b 'islayout))
      (vlax-for	o b
	(if (= (vla-get-objectname o) "AcDbPoint")
	  (vl-catch-all-apply 'vla-delete (list o))
  (foreach l a (vlax-put l 'lock -1))
  (vla-regen d acallviewports)
  (princ)
Message 3 of 8
AutoBIx
Thanks a lot RJP!!
It works flawlessy! You saved my days...
Message 4 of 8
braudpat
Hello @ronjonp
1) Thanks for your routine !
2) Please I would like a version 1.1 ...
Use standard ACAD selection ... I don't want to "filter" ALL Blocks !
THE HEALTH, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 5 of 8
ronjonp
@AutoBIx wrote:
Thanks a lot RJP!!
Glad to help 🍻
Message 6 of 8
ronjonp
@braudpat wrote:
Hello @ronjonp
Try this:
(defun c:foo (/ a b d n r s)
  ;; RJP » 2020-12-03
  (if (setq s (ssget '((0 . "INSERT"))))
    (progn (vlax-for l (vla-get-layers (setq d (vla-get-activedocument (vlax-get-acad-object))))
	   (setq b (vla-get-blocks d))
	   (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	     (or (vl-position (setq n (vla-get-effectivename (vlax-ename->vla-object e))) r)
		 (vlax-for o (vla-item b n)
	     (setq r (cons n r))
  (princ)
This still modifies the block definition so blocks outside of the selection set will change too. If you want just the blocks in the selset to change then the blocks would need to be converted to anonymous ( to make them unique ) then process .. but this is a bit messy IMO.
Message 7 of 8
GANGA_GUHA
Community Visitor
Community Visitor
I am not so familiar with lisp routine. can someone tell me what would be the command to be used after loading this in the dwg?
Message 8 of 8
braudpat
Hello
FOO <Enter>
Bye, Patrice
Patrice BRAUD
