LISP to reinsert dyn blk / help to finalize needed
karpki
1,165件の閲覧回数
9件の返信
メッセージ1/10
karpki
Hi
The aim is to reinsert dynamic block to the same insertion point
I'm trying to code but insertion point issue doesn't work
(defun c:DBRI (/ b obj bn ip)
  (vl-load-com)
  (setq
            b (entsel "\nSelect block: ")
            obj (vlax-ename->vla-object (car b))
            bn (vla-get-effectivename obj)
            ip (vla-get-InsertionPoint obj)
  (Command "-INSERT" bn ip "" "" "")
  (vla-delete obj)
   (princ)
Could you pls help to finalize it
Thanks in advance!
K
0 件のいいね
解決済み
1,166件の閲覧回数
9件の返信
返信 (9)
メッセージ2/10
hosneyalaa
TRY
(defun c: DBRI (/ b obj bn ip)
  (vl-load-com)
  (setq
            b (entsel "\ nSelect block:")
            obj (vlax-ename->vla-object (CAR b))
            ip (vlax-get obj 'insertionpoint)
  (vla-delete obj)
   (princ)
0 件のいいね
メッセージ3/10
karpki
unfortunatelly it doesn't work
0 件のいいね
メッセージ4/10
hosneyalaa
(defun c:testDBRI (/ b obj bn ip)
  (vl-load-com)
  (setq
  (Command "-INSERT" "bbbb" ip "" "" "")
  (vla-delete obj)
   (princ)
0 件のいいね
メッセージ5/10
karpki
It works this way
  (vl-load-com)
  (setq b (entsel "\nSelect block:"))
  (setq obj (vlax-ename->vla-object (car b)))
  (setq bn (vla-get-effectivename obj))
  (setq ip (vlax-safearray->list (vlax-variant-value (vlax-get-property obj 'InsertionPoint))))
  (vla-delete obj)
  (princ)
And now the question appears how to make so that OK button will be pressed automatically in the Enter Attributes window if I don't wanna change anything ?
0 件のいいね
メッセージ6/10
karpki
Test file
0 件のいいね
メッセージ7/10
karpki
Test file
0 件のいいね
メッセージ8/10
karpki
Thank you colleague!
I guess the main thing I have to say  it is sorry that I didn't post my own test file in the beginning.
Second thing: reinsert doesn't mean replace!
So the getting blockname (bn) is absolutely needed function for REinsertion
0 件のいいね
メッセージ9/10
hosneyalaa
解決済み
  (vl-load-com)
  (setq
    (setvar "ATTDIA" 0)
  (Command "-INSERT" "ABH.6.41" ip "" "" "" "" "" "" "" "")
  (setvar "ATTDIA" 1)
  ;;(vla-delete obj)
   (princ)
0 件のいいね
メッセージ10/10
karpki
Thank you!
Yes, attdia change helps, so the final code is
(vl-load-com)
(setvar "ATTDIA" 0)
(Command "-INSERT" bn ip "" "" "" "" "" "" "" "")
(setvar "ATTDIA" 1)
(vla-delete obj)
(princ)
